Old 09-18-2001, 02:02 PM   #136
Regional Moderator
Darkseid's Avatar
Nuno: Well that certainly clears things up. Just messing with you!
That seems to me, to be a better instruction manual saying basically the same thing that the not so "written word" oriented Schumacher manual was saying. That more anti-squat can add and detract traction in certain situations and vice versa with less anti-aquat.
Man and I thought that droop crap was complicated. I'll just try both methods and see which one I like best.
TLR 22...Tamiya F104...
Old 09-18-2001, 02:18 PM   #137
Nuno's Avatar
Send a message via ICQ to Nuno
In short I think that more anti squat will give you more rear traction when you accelerate because there will be more pressure in the rear tires and at the same time it will give you more on power steering because less weight will be transfered to the rear. But on the other hand it will give you less rear traction entering corners.
now let's talk about camber link positions and their effect.
ahhh just kidding!
Nuno is offline   Reply With Quote
Old 09-18-2001, 02:50 PM   #138
Regional Moderator
Darkseid's Avatar
Nuno: Please don't go there!!! Camber link location. NOOOOO!!!!! Thats another area where I just go with what the team drivers say and don't mess with it alot.
Old 09-18-2001, 05:35 PM   #139
MikeR's Avatar
Trader Rating: 15 (100%+)
This is what the Orion site says about anti-squat-
More anti-squat will give more 'driving traction': there will be more pressure on the rear tires as you accelerate, aspecially the first few meters. At the same time, it will give more on-power steering, because the car isn't squatting much. The disadvantage is that the car has an increased tendency to become unstable entering corners, aspecially in the rear. Reducing the anti-squat angle has the opposite effect: a lot less on power steering, and more rear traction when the car isn't accelerating as much anymore. The car will also be a lot more stable entering corners. It also affects the car's ability to handle bumps: more anti-squat will cause the car to bounce more when accelerating through bumps, but it will increase the car's ability to absorb the bumps when coasting. Reducing the anti-squat does the opposite: it improves the car's ability to soak up the bumps under power, but reduces it while coasting.
So I guess were both right if we weren't talking about the timing of grip . I still like the level hinge pins making the suspension freer and more efficient, especially on the coarse tracks I'm running on
MikeR is offline   Reply With Quote
Old 09-18-2001, 05:49 PM   #140
Regional Moderator
Darkseid's Avatar
MikeR: Heck that was really all I was trying to find out anyway. Which setting you liked.
Like I said, I think I will try it with the pins level.(or nearly level since the 4.1 only goes down to .5mm)
I'll let you know how I like it compared to the 3mm setup.
Old 09-19-2001, 12:44 AM   #141
porkybmx's Avatar
Send a message via AIM to porkybmx
Originally posted by MikeR
I've tried the Sorex tires but they don't seem to be as fast as Take-off 22's or 27's when your running on multi-use regular asphalt. Your tire selection will be the most important set-up. The p2k is still the stock motor to beat when geared at 6.0 starting point. And don't forget the split top plate modification! >)
MikeR, I don't believe I'm familiar with the split top plate mod. What exactly is it?
porkybmx is offline   Reply With Quote
Old 09-19-2001, 08:25 AM   #142
Trips's Avatar
Trader Rating: 16 (100%+)
The top dedck of the chassis is cut in two and a turnbuckle is used to connect the two pieces. This allows some torsional flex while preventing front to back flex.
I'm attaching a picture of it, the turnbuckle is partially obscured by the belt, but look closely and you should get the idea.
Trips
MARSHAL!!
Trips is offline   Reply With Quote
Old 09-19-2001, 08:58 AM   #143
Regional Moderator
Darkseid's Avatar
Trips: I hadn't seen you post on the thread in a while. I thought maybe you had moved away from Corally.....again!
Where you been? I hope they events over there in NY haven't hit you personally.
Old 09-19-2001, 11:11 AM   #144
MikeR's Avatar
Yes, the split top plate really helped settle down my car and made it even more stable in corners and when you put a wheel on a dot or uneven surface the car stays planted still. Just much more consistant.
Trips- Will get that box out today for you. Mucho Gracias!
Old 09-19-2001, 12:18 PM   #145
Regional Moderator
Darkseid's Avatar
I still haven't tried the upper deck mod. I don't want to cut my only upper deck. Maybe once I get another upper deck I'll give it a try. The car handles great as is, I cant imagine it getting better. But I will defintly try as soon as I get the chance.
Old 09-19-2001, 03:49 PM   #146
Trips's Avatar
I haven't moved away yet, but I did run a XXX-S last Saturday night, and it was on RAILS... My Corally felt a little bit slow through the corners in comparison, but easily as fast or maybe a bit faster on the straights.
I might try the topdeck mod this weekend... as of now I can't decide which car to run...
Trips
MARSHAL!!
Old 09-19-2001, 08:44 PM   #147
Regional Moderator
Darkseid's Avatar
Trips: Yeah, those Losi's are like trains going through the turns. Just plain on rails.
Old 09-19-2001, 08:55 PM   #148
Regional Moderator
Darkseid's Avatar
Hey MikeR: I just visted the Yokomo thread and they were discussing placing a power cap between the + and - polls on your reciever. They(and apparently some team drivers like Hara and companies like GM) say it helps with interference when running low turn motors or super high speed servos.
You should go check out their thread and see what they have to say about it. daniz24 has a pic of his car there which shows how he has it hooked up.
I figured with the interference problems you have had, you would be interested. That is unless that XXL has already solved your problems.
Old 09-19-2001, 09:05 PM   #149
porkybmx's Avatar
Thanks Trips, the visual aid was very helpful. I just might try that this weekend.
Old 09-20-2001, 09:37 AM   #150
MikeR's Avatar
Very cool, thanks Darkside. I will definately keep that in my bag of tricks to fix any glitching I might have now....that's some pretty interesting stuff.
NEW CLUB OPENNED IN SOUTH AUSTRALIA - NORTH EAST MODEL CAR CLUB VintageFrog1 Australian Racing 2226 08-17-2009 04:47 PM
ATTENTION CORALLY RDX OWNERS hotwheels1 R/C Items: For Sale/Trade 2 08-22-2006 08:26 PM
club vs club race at larry's coming soon!!! al jones Racing Forum 5 07-05-2003 12:11 PM
Corally owners octavio Electric On-Road 1 05-15-2003 06:30 AM
Aussie Corally Owners... black-knight Australian Racing 25 03-30-2003 01:19 AM
