A RWD R/C drift car
A RWD R/C drift car
In the real world, 90+% of those drift cars are rear-wheel drive. So if anyone knows any car maker makes a "real" r/c drift car, please post a link here. Thanks.
Here is a video I found on youtube that makes me even more interested in drifting. http://www.youtube.com/watch?v=W0QeISN0oZU
In the real world, the cars are 1000 times heavier, there is a different weight bias, forces are multiplied by larger factor (friction and acceleration especially), you are in the car so can feel it breaking loose, and probably a whole lot of things I hadn't thought about.
At the end of the day, 4wd trumps RC drifting withuot a doubt
I think it's all about the right parts & setup, and driving skills. Here is a good website that talks about Formula Drift: http://driftjapan.com/blog/
How to build a drift car: http://driftjapan.com/blog/car-parts...d-a-drift-car/
My goal is to make scale r/c cars look and drive as close to real cars as possible.
There are a lot of cars that could be converted to RWD by removing the center driveshaft, one of the belts, front CVD/dogbones or any combination thereof depending on the vehicle you are working with. That is probably your best bet, because you can easily convert back and forth. Maybe get the hang of drifting with 4WD then experiment with the RWD. I think it is going to be very difficult with RWD, but I'm sure it's possible with enough practice and finesse (and a properly set up vehicle).
if you want "RWD" drifting you should run upto 200% overdrive.
it's the best way for now, it's still 4x4 but the rear wheels have more RPM.
works well, you can find info on www.csjunkies.com
http://www.youtube.com/watch?v=RTx_5YNwpKo
http://www.youtube.com/watch?v=UNe3o75KmjA
Because if you could calculate the power to weight ratio of an r/c in scale with a real car it'd be like having a V24 with 5000ft/lb of torque. Match that with plastic drift tires and all you'll get are doughnuts. I would suggest if you want to just see it happen, turn your throttle epa down to like 30 and see if you can get some semblance of control.
I understand totally why those car, ESC, motor, and battery makers want you to buy their products and then educate you to put on some no-traction plastic tires to drift. Huh? Maybe some harder rubber slick tires + 540 motor? I'll let you draw your own conclusion on this.
