Old 01-23-2013, 02:41 PM   #1
Exclamation Motor info... New to electric
Hi i have been running off road nitros for the last year and have recently got my first electric rc... I have been looking into motor changes and was wondering what the '60t' or 8t' means... Which is better? Thanks in advance, Ben
Benault1990 is offline   Reply With Quote
Old 01-23-2013, 02:58 PM   #2
klaymon's Avatar
Trader Rating: 71 (100%+)
The "T" stands for turns. It's the number of times the wire inside the motor is wound around the stator. A motor with a lower turn count is a faster motor. For example, a 6.5t is faster than a 13.5t. Very high turn motors (35 and up) are generally used in crawler applications. Off road racing applications can use anything from a 17.5 all the way up to a 6.5. However, lower turn motors can be detrimental depending on the surface. On a high traction clay, you could run a 7.5, but on really loose stuff that much motor can be too much and not let you put the power down. More powerful is not always better.
klaymon is offline   Reply With Quote
*New to electric* Need lipo charger info, setup info for tekin FNS156 Electric Off-Road 6 12-11-2011 04:02 PM
New to Electric & got a few Questions!! Teflon Electric Off-Road 14 02-02-2009 07:11 PM
New to electric? Questions? RGraves Rookie Zone 6 10-23-2008 03:10 PM
SEO by vBSEO 3.5.0
