Old 04-24-2013, 10:14 AM   #106
Originally Posted by mikpiz View Post
If you are talking about Chucks car its a exotek f1r built from a tamiya f104. Same as mine but with a few different options
Yes it is Chuck's car. After seeing the VBC run and driving it I think he's parking it and building the VBC.
www.norcarracing.com
NORCAR @ The Gate
old_dude is offline   Reply With Quote
Old 04-24-2013, 08:57 PM   #107
gijoe64's Avatar
Trader Rating: 30 (100%+)
Almost done
Raymon Robinson
ARC, LRP Go Blue!!
gijoe64 is offline   Reply With Quote
Old 04-24-2013, 09:00 PM   #108
gijoe64's Avatar
Raymon Robinson
ARC, LRP Go Blue!!
Old 04-25-2013, 04:28 AM   #109
FL_SilverEvo8's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to FL_SilverEvo8
Hey old dude. What gearing set up are you going with? I am useing the stock spur gear that came with the kit. That is an 95t. For my pinion gear I am using 32t. My ratio is 2.96. The motor I am using is an Tekin redline 21.5RPM
Off-Road - Durango:DEX210R(2wd Buggy), DESC210R(2wd SCT), DESC410R(4wd SCT)
On-Road - CRC: Gen-X 10 LE(WGT), X-Ray:T3 2011(VTA), X-Ray:T2 009(USGT) TRF 101(F-1), AE: RC10R5.1(Spec17.5)
Jeff's RC Studio Video>> http://www.youtube.com/watch?v=WtZ8-TV8Fs8&feature=share
FL_SilverEvo8 is offline   Reply With Quote
Old 04-25-2013, 04:30 AM   #110
What can I do to get my car to stop pushing through corners? More camber? more toe? More weight up front? What can be done?
Old 04-25-2013, 08:50 AM   #111
(1) Try softer front springs
(2) Remove a shim or both and use longer softer or medium springs
(3) More front tire sauce
(4) Stiffer center shock spring and or stiffer oil
(5) Raise the center shock at rear pivot aprox 3mm or lower front pivot 3mm
(6) More front toe out (only 1/2 deg.)
(7) Try Tamiya Ferrari front wing
(8) Maybe try a little more drag break in your radio, but not too much
(9) Try softer side springs
Only try one change at a time until you are happy. Remember, some of these changes may effect how the rear end reacts. Good luck.
all4fun is offline   Reply With Quote
Old 04-25-2013, 05:26 PM   #112
One more: Narrow the rear track.
NORCAR @ The Gate
Old 04-25-2013, 05:29 PM   #113
Oops, thats right, forgot that one Ron, lol.
Thanks.
Old 04-25-2013, 06:11 PM   #114
YoDog's Avatar
Trader Rating: 26 (100%+)
Any word on parts????
I'm wanting to get this car but The lack of parts support has me concerned. I need to be race ready by the middle of next month in order to run it in the RROC, Memorial weekend.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 04-25-2013, 06:41 PM   #115
Lessen's Avatar
Send a message via MSN to Lessen
Ahhh... so that's why he mentioned rent-a-ride.
"Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. "
Lessen is offline   Reply With Quote
Old 04-26-2013, 04:02 AM   #116
My car came with a 96t spur and I ran a 36t pinion, Shurspeed 21.5 and 2.50" dia tires (Pardus spec).
NORCAR @ The Gate
Old 04-28-2013, 11:02 AM   #117
I now need a new rear axle. That is what I get for running too hard on a 1/18 scale road course with a 1/10 scale car and open wheels. I hope the spares get in the states soon. Mean while I ordered a F104 rear axle and diff since the axle dia is the same. I just hope that the offset is similar.
NORCAR @ The Gate
Old 04-30-2013, 09:15 AM   #118
GryphunRacing's Avatar
Progress....
I still need to finish the front wing / body and lower the rear ride height.
New VBC Flash-04 F1-vbc1.jpg   New VBC Flash-04 F1-vbc2.jpg   New VBC Flash-04 F1-vbc3.jpg
In the Stable: VBC Flash-04, Tamiya F104X1, Tamiya F104v2
GryphunRacing is offline   Reply With Quote
Old 04-30-2013, 09:18 AM   #119
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
Looking really good!
IIGQ4U is offline   Reply With Quote
Old 04-30-2013, 12:21 PM   #120
Originally Posted by GryphunRacing View Post
Progress....
How do you plan on lowering the ride height?
thanks
chuck
mackin is offline   Reply With Quote
