Old 02-03-2014, 07:44 PM   #331
Regional Moderator
CarbonJoe's Avatar
Originally Posted by matt*strike View Post
Has anyone used the tuning haus chassis?
Yes, along with the Tuning Haus front and rear shims in order to get closer to a 3mm ride height. And his aluminum rear pod sliders. They have been bulletproof.
*** The Gate - Celebrating 7 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 02-04-2014, 05:16 PM   #332
matt*strike's Avatar
Trader Rating: 41 (100%+)
I'm getting ready to switch all my stuff over and just wanted to see if anyone else had.
Team Redline O.G.
Alpha Raceway ---Carbondale, IL
matt*strike is offline   Reply With Quote
Old 02-04-2014, 06:13 PM   #333
MAD916's Avatar
i switched this year from the 3 racing to the Flash... great car handles amazingly, the quality is great. Dave Ehrlich had the TQ this last week at the snowbirds going into round 4 but a bit of bad luck got in his way....
Timezone Raceway Park " on-road outdoor european style road course.
Timezone II 60'x100' indoor carpet track. Host of the ROAR 2011 Carpet Nat's.
Timezonehobbies.com your new source for online RC products.
MAD916 is offline   Reply With Quote
Old 02-05-2014, 08:15 AM   #334
Default wtb
Looking at getting a vbc flash who has the best price on a new kit? Or better yet does anyone have one that they are thinking about selling ?
bigtee is offline   Reply With Quote
Old 02-05-2014, 09:59 AM   #335
Gridworks Racing's Avatar
The Tuning Haus chassis is actually very good. Bill was in the A at the IIC with his and the chassis is a very good option to the stock chassis.
Pricing for the Flash-04 is pretty much set at $339. It really is a good car that is capable of competing with any of the others.
☆★☆The Holidays are here, Be Merry and stock up on the stuff you want☆★☆
☆★☆ Gridworks Racing ☆★☆ Your Source for G-Daub, Blitz Racing Bodies, DryFluid, Epic 1 Designs, Hobbywing, LRP, R1 Wurks, Solaris Tires, Sorex, Team Powers, Tuning Haus, VBC Racing and More!
Gridworks Racing is offline   Reply With Quote
Old 02-05-2014, 02:50 PM   #336
I love mine just need some more track time with it
Team Redline O.G.
Old 02-06-2014, 04:26 PM   #337
YoDog's Avatar
Trader Rating: 26 (100%+)
Stormer has it in stock at @ $269!!!
I almost sold mine as I could not put any power down and was very inconsistent. I was soooo frustrated... then I read Brian Bodine's article on setting up a pan chassis on RCPITWHORES. Changed my outlook completely!
I learned what I should do with my setup and BAM! the car was so dialed. Steering became consistent, I could pull the trigger without fear that the car was going to loop when coming out of a corner. Just a pure pleasure to drive after understanding what the changes would do.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 02-16-2014, 02:13 PM   #338
Sorry it's taken me so long to join in here...I've been running a version of the Flash 04 for almost a year and would be happy to answer any questions anyone may have. My experience has been both carpet and asphalt using Pit Shimizu and Pardus tires on carpet.
Also, my thanks to RC Tech users that have liked the Tuning Haus FB page.
Kind Regards,
Bill
Bill Jeric is offline   Reply With Quote
Old 02-16-2014, 04:22 PM   #339
How do you keep the Pardus front wheels from cracking where the bearings sits.
Team Redline O.G.
Old 02-17-2014, 09:41 AM   #340
I've heard of this but never experienced it, as I tend to run my front bearings dry as I believe the problem may be caused by bearing oil attacking the wheel material. I would try running the front bearings dry or with just a tiny drop of oil after a thorough cleaning and see if that doesn't eliminate the problem.
Bill
Old 02-17-2014, 10:44 AM   #341
Go to a Sear's or Ace hardware. They have plastic washers with an inside diameter of 1/2 inch. These will slip right over where the inside bearing goes. Then just shoo goo it in place. Cheap fix!
chuck
mackin is offline   Reply With Quote
Old 02-17-2014, 05:34 PM   #342
Team Redline O.G.
Old 02-19-2014, 09:12 AM   #343
Nego's Avatar
Trader Rating: 71 (100%+)
Hey guys u just pick up a flash-04 from a buddy of mine ,this will be my first F1 any advice on body setups and any problems i may run into? I fixed one all ready one of the steering arms the middle shaft that goes tru the arm the tread was strippide had to put one screw that would go from the bottom to the top and held it with a nut hope it works,any advice will be welcome tks.
Project X 1/10 pancar,17.5GT,BMI,yokomo,Associted F6.
Nego is offline   Reply With Quote
Old 04-02-2014, 12:58 PM   #344
Default steering set up
What's the best steering setup? Using the kit steering rack or a direct setup reason asking I see vbc did away with it on the lighting f. I currently just setup my steering direct have not had the chance of testing it out. I also use the crc center shock setup. Can someone post some pics of there direct steering setup? Thank.
Old 04-15-2014, 07:40 PM   #345
Nego's Avatar
This is what I did to mine. Hope it helps.
