Old 12-17-2013, 01:06 PM   #301
MAD916's Avatar
Had a great weekend this last Saturday at the Seattle Can-am Challenge. Took the TQ and set a new track record. Finished 2nd with a good battle with a local fast guy, but oh well a good weekend with the Flash. I'm thinking that the A-Main starting at 2:00am didn't help much man I was crunchy
Timezone Raceway Park " on-road outdoor european style road course.
Timezone II 60'x100' indoor carpet track. Host of the ROAR 2011 Carpet Nat's.
Timezonehobbies.com your new source for online RC products.
MAD916 is offline   Reply With Quote
Old 12-17-2013, 01:08 PM   #302
Gridworks Racing's Avatar
Great result and most certainly a long day.
☆★☆The Holidays are here, Be Merry and stock up on the stuff you want☆★☆
☆★☆ Gridworks Racing ☆★☆ Your Source for G-Daub, Blitz Racing Bodies, DryFluid, Epic 1 Designs, Hobbywing, LRP, R1 Wurks, Solaris Tires, Sorex, Team Powers, Tuning Haus, VBC Racing and More!
Gridworks Racing is offline   Reply With Quote
Old 12-17-2013, 02:25 PM   #303
Jerry P's Avatar
Trader Rating: 44 (100%+)
setup please.
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 12-19-2013, 12:28 PM   #304
MAD916's Avatar
Sorry Jerry Busy week.... here is what I have so far
Front
Pit 0571 Tires on exotek 3mm offset rims
med front spring 1mm droop
-1.25 deg camber
+.50 deg toe out
Direct Servo connection without steering rack
approx +2mm ackerman
ride height 4.5mm
Center
30wt shock oil
Red Spring
100,000 wt in tubes
med side spring with 0 float
Rear
Pit 0572 with exotek 3mm offset wheels
93/30 gearing
ride height 4.5mm
- 3 degree camber and -3 rear toe............. just kidding. Hope that helps
Old 12-20-2013, 03:27 PM   #305
YoDog's Avatar
Trader Rating: 25 (100%+)
Front
-1.25 deg camber
+.50 deg toe out
ride height 4.5mm
Center
30wt shock oil
Red Spring
100,000 wt in tubes
Rear
93/30 gearing
ride height 4.5mm
How much middle droop are you running? I have been consistently having on power rear traction issues which cause over steer coming out of the corners. Trying to fully understand Pan chassis dynamics since it seems so different from TC. Any suggestions on a source of learning for Link chassis knowledge?
There is plenty out there for full suspension cars but the pan car info is a bit fragmented.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 12-20-2013, 04:05 PM   #306
Team VBC Racing's Avatar
Try -1mm. The more rear droop usually cause the oversteer off power.
Dave Ehrlich
Team Manager
VBCracingusa.com
North & South America
Canada
Team VBC Racing is offline   Reply With Quote
Old 12-21-2013, 05:00 PM   #307
Korey Harbke's Avatar
Front
-1.25 deg camber
+.50 deg toe out
ride height 4.5mm
Center
30wt shock oil
Red Spring
100,000 wt in tubes
Rear
93/30 gearing
ride height 4.5mm
Mark's car looked great.
What did you think of direct servo setup vs using the steering rack?
-Korey
Pro Spec America/Apex RC - Team ORCA - Awesomatix USA - Roche RC USA - AVID - Sweep - Protoform - Pro-One RC - Slapmaster Tools - Hebiki Design Works - Turtlemaster Racing - Seattle RC Racers - Timezone Hobbies
Korey Harbke is offline   Reply With Quote
Old 12-21-2013, 10:01 PM   #308
mtveten's Avatar
Trader Rating: 27 (100%+)
When I switched to the direct setup steering smoothed out and was much more consistent. The orings under the links were the other big change to improve car control in traffic
mtveten is offline   Reply With Quote
Old 12-28-2013, 11:36 AM   #309
ouinon's Avatar
Default bodies ?
Hi
New vbc flash04 man... i would like to know which body do you use in your VBC?
I need a body wich don't need so much preparation and work.
I have a f104 body ferrari F60 but its difficult to use it.....
F103 13,5T Ezrun
F104 Brushless 10T ezrun, soon F104W Ferrari 643
Ferrari 412T1 body, Toyota GT one, Porsche GT1, Renault RE30, Lotus 2010, Ligier.
Futaba 3PM 2,4GHZ
Planes: Twinstar II, Cool3D, DX7 SpeKtrum.
ouinon is offline   Reply With Quote
Old 12-28-2013, 07:38 PM   #310
matt*strike's Avatar
Trader Rating: 41 (100%+)
Ferrari 2012
Team Redline O.G.
Alpha Raceway ---Carbondale, IL
matt*strike is offline   Reply With Quote
Old 12-29-2013, 07:53 AM   #311
Jerry P's Avatar
any one know what size the turnbuckles for the upper are are? i believe they are 4mm x 25mm from the part number but i want to make sure because i bent both sides up bad and i rather fix them correctly.
Jerry P
Old 12-29-2013, 09:03 AM   #312
MAD916's Avatar
Jerry I'll confirm as soon as I get up at the track in a couple hours....
Old 12-29-2013, 09:20 AM   #313
Jerry P's Avatar
Thanks Mark.
Jerry P
Old 12-30-2013, 10:51 AM   #314
ouinon's Avatar
Originally Posted by ouinon View Post
Hi
I purchased it, thanks !
F103 13,5T Ezrun
Futaba 3PM 2,4GHZ
Old 01-03-2014, 05:00 PM   #315
Jerry P's Avatar
anyone know the answer to this? i really want to run my car but dont want to deal with the stock camber links.
Jerry P
SEO by vBSEO 3.5.0
