Old 10-30-2013, 09:55 PM   #256
Gridworks Racing's Avatar
Originally Posted by BlackedOutREVO View Post
VBC racing shop has a 15% off discount going on.
Can't wait to run mine this winter, such a fun class!
Yep, thanks.
Ends tomorrow night.
See you guys at the track.
☆★☆The Holidays are here, Be Merry and stock up on the stuff you want☆★☆
☆★☆ Gridworks Racing ☆★☆ Your Source for G-Daub, Blitz Racing Bodies, DryFluid, Epic 1 Designs, Hobbywing, LRP, R1 Wurks, Solaris Tires, Sorex, Team Powers, Tuning Haus, VBC Racing and More!
Gridworks Racing is offline   Reply With Quote
Old 10-30-2013, 10:31 PM   #257
Team VBC Racing's Avatar
Originally Posted by Jerry P View Post
Do you guys cut down the link between the servo and steering rack? it's a little long so it wont center. Or do you just just off set the servo arm?
We just run it offset
Dave Ehrlich
Team Manager
VBCracingusa.com
North & South America
Canada
Team VBC Racing is offline   Reply With Quote
Old 10-30-2013, 11:27 PM   #258
Korey Harbke's Avatar
Yea. Oddly I left the steering link as short as possible and it worked out to have equal throws on the radio to get full lock in both directions. So I left it!
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 10-31-2013, 05:39 AM   #259
celt's Avatar
Default wow...
Does this chassis drive as sexy as it looks?
The TRF101 was a major dissapointment.
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 10-31-2013, 06:10 AM   #260
Ph3nyx's Avatar
it works realy well ! one of the top 3 F1 in my own opinion it has some flaws (the front trackrod for exemple) but this can be easly fixed
the first F1 RC resource in french : www.rcf1.fr
Ph3nyx is offline   Reply With Quote
Old 10-31-2013, 03:22 PM   #261
Jerry P's Avatar
Trader Rating: 44 (100%+)
Is your ii setup posted anywhere?
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 10-31-2013, 03:27 PM   #262
Default IIC Flash setup
Here ya go
Dave Ehrlich
Team Manager
VBCracingusa.com
Canada
Old 11-01-2013, 04:28 AM   #263
Jerry P's Avatar
Here ya go
Dave: Just to confirm the Caster shims go at the front of the arm. From the way the setup sheet looks there would be no clear way to designate rear of the arm. My car is together but i'm going to over the setup sheet and try your setup instead.
Jerry P
Old 11-05-2013, 04:10 AM   #264
Jerry P's Avatar
it sure is quiet in here..
anyways here is my new flash.. just needs paint and pinion..
Jerry P
Old 11-05-2013, 05:03 AM   #265
Ph3nyx's Avatar
McLaren body ? did you put the narrower sides ?
Old 11-05-2013, 05:22 AM   #266
Jerry P's Avatar
I bought the F60 body. I will fit it tonight and see what needs to be moved. I had to move the wing back about 2mm to make sure it didnt hit the spur. I also trimmed the wing on the left side so i could adjust the rear end as high as it could go.
Jerry P
Old 11-05-2013, 05:52 AM   #267
Ph3nyx's Avatar
i've tried the F2012 body on the VBC , it fit but without the narrow sides. (or maybe with a large trimming for the body post supports )
Old 11-06-2013, 09:55 PM   #268
Default Spring Rates for VBC Flash
Can anyone tell me what color spring goes with the H-M-S that is on the setup sheet?? If you look at the above posted set up by Dave under the front spring and roll spring it says either H, M, or S. Which spring that comes with the kit correlates to the correct setting??
VegasGator is offline   Reply With Quote
Old 11-06-2013, 10:01 PM   #269
Silver - Soft
Gold - Medium
Black - Hard
This applies for both front springs and side springs.
Old 11-06-2013, 11:38 PM   #270
Default Center Shock Spring
Thank you Korey for your response
Per Dave's set up above what Green spring are we referring to? Can someone give me a part number of this spring please.
