Old 07-16-2013, 03:33 PM   #226
HenryC's Avatar
Originally Posted by BullFrog View Post
HenryC- I take it you will be at superior this weekend?I've got both Foams and rubber tires and a variety of tire tractions.I know you won't have the foams I've got (GQ Tires) and as for rubber break them in first.I tried Pardus but did not break them in and had problems. Now that they are broken in they work good. I"ll be glad to help you out the best I can. Just look fo Team BullFrog I'm easy to spot.
Yes, I will out on Sunday. I will be pitting with Rich. I have not run on asphalt in over 25 years. Just got back into racing last year and have only been running at Plant City (indoor with A/C, well worth the drive from Orlando each week). I remember running the state series back in the late 80's and burning up while pitting on asphalt. Hopefully it will not be too hot on Sunday.
I have both A and B Tamiya foams and several sets of pit rubber to try out. On carpet the Tamiya foams have my Flash04 running like a WGT. Not so much on rubber (yet).
HenryC is offline   Reply With Quote
Old 07-16-2013, 06:26 PM   #227
HenryC's Avatar
Default Rear axle adjustable mounts
Hey Bill, you wouldn't happen to have an extra rear axle mount you can sell me on Sunday? I have one broken but I have the backend holding together for now, but one good shot and it's all over. CRC told me a few weeks ago that they would not have any in stock until end of July at the earliest.
Old 07-16-2013, 06:40 PM   #228
I don't think I have that part. I'll look later.
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT Racing USA (17.5 foam), Formula 1 and Home Track is 386 RaceWay.
BullFrog is offline   Reply With Quote
Old 07-31-2013, 06:10 AM   #229
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
The VBC F1 ran great this weekend at the UF1 Midwest series race #1 at NORCAR at The Gate.
Track was very flowing and high bite.
Here's a pic of my ride
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 07-31-2013, 07:11 AM   #230
Ph3nyx's Avatar
What tires do you use for this race ?
the first F1 RC resource in french : www.rcf1.fr
Ph3nyx is offline   Reply With Quote
Old 07-31-2013, 07:20 AM   #231
sg1
sg1's Avatar
Everyone uses the Pardus "spec" tire.
Old 07-31-2013, 07:24 AM   #232
sg1
sg1's Avatar
Here's a link to Saturday's club race.
The track was altered slightly for Sunday's UF1 race.
I'm the white F1
https://www.youtube.com/watch?v=L5xj...e_gdata_player
Old 07-31-2013, 08:30 AM   #233
Ph3nyx's Avatar
I'm the white F1
I've tried the pardus on my local carpet track but i had issues with too much lateral grip cause the car to flip on fasts corners. How did you manage that on your track ? (if some drivers have the problem ?)
Very nice race , can i use the vidéo for rcf1.fr ?
Old 07-31-2013, 08:31 AM   #234
Wayne failed to mention he won both the club race on Sat and the UF1 Midwest race on Sun.
mackin is offline   Reply With Quote
Old 07-31-2013, 08:46 AM   #235
sg1
sg1's Avatar
I added more travel to the front and softened the rear.
The suspesion rolled and didn't transfer the weight to the tires.
The car wasn't prone to traction roll as long as you drive it smoothly
I did notice a small variance in the Pardus tires, I had to change fronts when I cracked a rim. I gained some front bite that did cause the car to traction roll when I was aggressive. At that point I removed some camber (from 3* to 1.5*) and used less tire traction on the fronts (from 3/4 to 1/3 inside, SXT).
There's that video and a few others on youtube you can repost.
Old 07-31-2013, 09:00 AM   #236
Regional Moderator
CarbonJoe's Avatar
You can also super glue the side walls of the tires to both stiffen them a little and to make them slide instead of grab during a turn. After cleaning the tires, my car was flipping on tight turns. After super glue, no more flipping. Same track as the posted video.
Note that my car wasn't traction rolling until I cleaned the tires off. No other changes were made to the setup. For the 3rd main, I super glued the side walls and used no traction compound, and didn't flip once in 15 minutes, and finished 4th in the 3rd round.
*** The Gate - Celebrating 7 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 07-31-2013, 09:40 AM   #237
Ph3nyx's Avatar
Ok thank you both for your advices, I'll try thoses solutions next week end
Old 07-31-2013, 11:02 AM   #238
sg1
sg1's Avatar
Let us know how it goes!
Old 07-31-2013, 12:32 PM   #239
Solara's Avatar
Trader Rating: 16 (100%+)
Quick fix is super glue, make sure use a wet towel and glaze thru the whole side wall but NOT letting the glue dry itself..you want a thin layer of the CA on the side way, possible a very outside edge of the tires...depends on how much traction you will have on the carpet. Also...only on front tires...on rear tires, I only put very little on the side wall (not the edge) just to make the rear side wall stiffer.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Old 07-31-2013, 06:51 PM   #240
Ph3nyx's Avatar
i'm not sure to understand the process (i'm french , i'm not used to speak technical language). What do you do with the wet towel ? what's exactly is a glaze ? do you have a ref maybe ?
Thank you
SEO by vBSEO 3.5.0
