Old 06-21-2013, 08:22 AM   #196
carl jr's Avatar
Has anybody tried the new wide front end.
carl jr is offline   Reply With Quote
Old 06-22-2013, 04:48 AM   #197
Rouleau's Avatar
Carl do you have this car?
Rouleau is offline   Reply With Quote
Old 06-24-2013, 05:06 AM   #198
carl jr's Avatar
Its on order
Old 06-24-2013, 03:56 PM   #199
Rouleau's Avatar
nice mine on its way i'll be at madness saturday with it hopefully
Old 06-24-2013, 04:03 PM   #200
carl jr's Avatar
Good I'll be there as well
Old 06-25-2013, 05:37 AM   #201
Weak spots we have found on the car are: Turnbuckles in combination with the cutouts in the arms for camber adjustments make this a weak area. Rods in the front should be replaced with Lundsford pieces. The ride height adjuster in the rear is also a weak area. We also need to know the rate of the shock springs or just replace it with an oncore shock and springs. Other than that the car is very good and easy to drive and tune.
chuck
mackin is offline   Reply With Quote
Old 06-25-2013, 07:34 AM   #202
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
I believe that the center shock is the same that is used in their other cars, as well as the springs. If that is the case, the following chart should help:
IIGQ4U is offline   Reply With Quote
Old 06-25-2013, 09:21 AM   #203
Thanks, Do you know of other manufactures springs that would work?
Old 06-26-2013, 03:51 AM   #204
Is this the 200mm kit or something else? UF1 rules that we follow, limit the cars to 190.
www.norcarracing.com
NORCAR @ The Gate
old_dude is offline   Reply With Quote
Old 06-26-2013, 04:53 AM   #205
FL_SilverEvo8's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to FL_SilverEvo8
I have tried it and loved it. But like what other people were saying the weakest part on this f1 car is the front. Broke on of the arms. But for the time I did have it wide it was great.
Off-Road - Durango:DEX210R(2wd Buggy), DESC210R(2wd SCT), DESC410R(4wd SCT)
On-Road - CRC: Gen-X 10 LE(WGT), X-Ray:T3 2011(VTA), X-Ray:T2 009(USGT) TRF 101(F-1), AE: RC10R5.1(Spec17.5)
Jeff's RC Studio Video>> http://www.youtube.com/watch?v=WtZ8-TV8Fs8&feature=share
FL_SilverEvo8 is offline   Reply With Quote
Old 06-26-2013, 08:14 PM   #206
This car better than F104WGP ?
E36M3 is offline   Reply With Quote
Old 06-28-2013, 08:00 AM   #207
I think it is better. (I do have both) If I can get the front arms to stop breaking.
Old 07-03-2013, 12:18 AM   #208
Can anyone pls compare this with the TRF 101 in terms of performance ?
Old 07-03-2013, 06:34 AM   #209
shadowracer24's Avatar
I have both and the only real diff. I have seen is that the flash is alot more fragile when in a hard crash situation. Have lost both front arms and rear bearing carriers with wall slaps. Only thing lost on the 101 was a servo saver. With the same setup on both cars they both run the same lap times and drive the same to me anyway. the 101 is just more durable and a little harder to setup on frontend. Kinda limited on settings you can quickly put on the front but I like both cars. Use the flash for 21.5 class and the 101 for the more open classes.
Richard Carpenter
SPEEDZONE Batteries Team Driver
BMI Team Driver
2014 F.E.D.S. Mod Sprint and Sportsman Late Model Champion
2013 FSERA World GT State Champion
shadowracer24 is offline   Reply With Quote
Old 07-03-2013, 10:20 AM   #210
Thanks, in that case, I'll stick to my Flash (and wgp).
