New VBC Flash-04 F1
#182
Bodies ...
Good looking car.
I see that it says F104 bodies fit, but reading here sounds like the bodies fit has issues, requiring lots of trimming and not covering the chassis.
Can someone recommend a body that fits well?
Where is a good source to get F1 bodies and front/rear wings?
Thanks.
Thanks.
#188
Because I lost (dropped on the ground) the side spring holder I found a better one piece holder. Instead of the set screw and the spring holder you get a one piece Alum. 3mm screw.and spring holder from corally #75548 for 1/12th car or 1/10th. I've now got them on my F1.
#190
Any suggestions on how to improve rear on power grip? The car is a real handful under acceleration, even a little. I'm running hard Shimizu rears and Medium Shimizu fronts. Everyone will probably say run softer rears but all the other cars at my track are running hard and don't seem to have the same problem. I have been thinking that I need more weight transfer to the rear while on power.
#192
Fl silver have you tried boiling the arms. try it first on one of your broken arms. we used to do that with the old Arms years ago. I have not tried it yet.
YoDog-I tried Pardus spec tires last weekend outdoors . Here what I experimented with and will try out this weekend(if I can).
front X- 20 front spring Asc (1/10)
Rear Blue sides progressive. center a very soft old associated Black spring- softer than Tamiya Red.
Also also readjusted my radio -EXpo both steering and trottlw to get rid of the problem you mentioned.Also who sells the tit turnbuckels.
#193
Thanks for the input although it's a bit difficult to understand. Probably your accent.
Ti front turnbuckles are Lunsford 4x20mm #1026
I also found that 3 racing makes them too (model #420) but I was having trouble finding them in the U.S.
