Old 05-14-2013, 06:08 PM   #166
YoDog's Avatar
Trader Rating: 26 (100%+)
Originally Posted by gijoe64 View Post
The Flash 4 has tons of rear grip, this is not a F104 you will have to stiffin up the car to get the push out. Don't think Tamiya setup on the VBC.
your tire selection will have to change also.
I figured that the setup won't be like the F104 besides this is my first venture into an F1 car. Been running TC and WGT for awhile. I just changed the mounting of my steering servo to get the battery further forward and that seems to have helped. I'm running a shorty pack of course.
I hear the guys at Norcal are running hard rears and medium fronts for pavement. I have both medium and soft fronts but I'm currently stuck with the Pardus and the Ride R1 premounts for the rear as the preferred rears were out of stock.
I'm gonna try to get some track time in tomorrow.
Wish me luck.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 05-15-2013, 05:53 AM   #167
FL_SilverEvo8's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to FL_SilverEvo8
I am having the same problem. My F-1 pushes really bad around turns. I don't what kind of set up I should do. I am running Silver spring up front and on the sides. For the middle I am running what the kit came with alone with the shock oil that it came with also.
Would like to know what most of you running for a good set up. I am trying the wide arms right now to see how it does. I like them but can't for the life of me get this thing to stop pushing. Going in and out of turns.
Also with foam tires are you all cutting them down? If so what are you cutting them to? Front and rears. I had someone tell me that I needed to cut the tires down.
Off-Road - Durango:DEX210R(2wd Buggy), DESC210R(2wd SCT), DESC410R(4wd SCT)
On-Road - CRC: Gen-X 10 LE(WGT), X-Ray:T3 2011(VTA), X-Ray:T2 009(USGT) TRF 101(F-1), AE: RC10R5.1(Spec17.5)
Jeff's RC Studio Video>> http://www.youtube.com/watch?v=WtZ8-TV8Fs8&feature=share
FL_SilverEvo8 is offline   Reply With Quote
Old 05-15-2013, 10:37 AM   #168
YoDog's Avatar
If you are using a shorty pack, I think it's important to get it as far forward as possible. My balance has improved quite a bit by doing this.
Old 05-16-2013, 12:09 PM   #169
YoDog's Avatar
Ran the car yesterday and initially it was terrible. (Low to Med grip asphalt, smooth) Pushed like crazy and would spin out under power. (couldn't get any heat into the tires)
The things that fixed it from the base setup are as follows:
1) Medium rear and soft front tires
2) Silver springs in front
3) All shims under steering blocks (leave out 1mm spacer on kingpins for added droop "optional")
4) Silver side springs just touching to 0.5mm gap (depending on grip level)
5) 5mm ride height rear (lowest I could get with rubber tires)
6) 5.5mm mid
7) 4.5mm front
8) 25% drag brake to gain corner entry steering
9) 2mm under forward link ball (rear steering)
Old 05-17-2013, 03:42 AM   #170
Grand Finale at The Gate this weekend. Should be several 04 cars in the house. UF1 rules. First true test of the car. I'll have some pictures to post later.
chuck
mackin is offline   Reply With Quote
Old 05-17-2013, 07:26 AM   #171
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
Keep us posted!
IIGQ4U is offline   Reply With Quote
Old 05-18-2013, 07:46 PM   #172
chuck
Pictures are posted on the NORCAR R/C FB site. I ended up winning F1 with my VBC Flash. It takes a different driving style. You can't throw the car around, you really have to be smooth. Didn't break anything or have any real problems with the car.
chuck
Old 05-20-2013, 12:14 PM   #173
GryphunRacing's Avatar
actually had time to work on the F2012 body...
Need to cut in the rear to take into account the CF plates that stick out
Also need to cut the front to fit the arms AND the steering link that moves outwards...
Still need to sand and smooth the outer edges and figure out a livery...
New VBC Flash-04 F1-left-front.jpg   New VBC Flash-04 F1-left-rear2.jpg   New VBC Flash-04 F1-left-rear.jpg   New VBC Flash-04 F1-right-front2.jpg   New VBC Flash-04 F1-right-front-steering-link-out.jpg
In the Stable: VBC Flash-04, Tamiya F104X1, Tamiya F104v2
GryphunRacing is offline   Reply With Quote
Old 05-27-2013, 01:47 PM   #174
I found out that running a stiffer spring in the middle calmed down the push out the car was doing on me. I am running a Team Associated Touring Spring(#3946 - copper, 25lbs.) for my middle spring.
Now should I cut my foam tires? If so what size should they be? I was told that need to be.
Old 05-27-2013, 01:50 PM   #175
2013 F1 and Mini Nationals
Look whats going to be happening. Don't know if any of you all want to go to be it would be nice to see some more VBC's out there. And help to get some tips and tricks on set up and stuff.
Old 05-28-2013, 12:47 PM   #176
Besides the guys at The Gate have any of you actually raced your cars yet?
Old 05-28-2013, 02:30 PM   #177
shadowracer24's Avatar
Should be getting mine at the end of the week and I plan on coming, hoping to also have the state races there next season. A bunch of us are pushing really hard for an F1 class.
Richard Carpenter
SPEEDZONE Batteries Team Driver
BMI Team Driver
2014 F.E.D.S. Mod Sprint and Sportsman Late Model Champion
2013 FSERA World GT State Champion
shadowracer24 is offline   Reply With Quote
Old 06-02-2013, 06:32 AM   #178
Trader Rating: 20 (95%+)
3 of us in St. Louis have them. We've raced them on asphalt and have been practicing on carpet. The car is so fun to drive that my tc has just been collecting dust since I got it.
Stlfc is offline   Reply With Quote
Old 06-02-2013, 06:50 PM   #179
Ph3nyx's Avatar
Hi guys
i did a quick review of the flash04 in french. Maybe you can find some interesting things
+ YouTube Video
the first F1 RC resource in french : www.rcf1.fr
Ph3nyx is offline   Reply With Quote
Old 06-08-2013, 03:07 AM   #180
So, are the silver springs the softest ?
E36M3 is offline   Reply With Quote
