LRP Quantum Comp2 and HRS
Can anyone confrirm wether the quantum comp 2 and futaba HRS are compatible. I have one of the earlier quantums and it behaves weird.
It works with no problems.
I have problems getting the speedo to 'tie in' to the transmitter.
I can't seem to get the full throttle l.e.d. to light. |
I know the QC2 has problems with KO servos becasue of an issue with the BEC out of the QC2 to the reciever. If you have a KO servo that could be more of your issue. I suggest you change out to like an airtronics servo or hitec(sorry I never suggest them) see if the problem persists. That is why I use either Artronics Servos or Futaba servos with my QC2's.
Hope this helps. Stephen <>< |
Thanks Mr Shookie. I'm using a Futaba digital (9550) and still have this problem. I'm going to try a Novak GTX to see if this solves the problem.
I have run the Q2 with S9550 servo and HRS and no problems. However, Profile 4 does not work in HRS mode.
Like KilRuf said, from othr people experiences, Ive read that the QC2 wont work with HRS in punch control mode 4 because that is the reactive mode and for some reason, the reactive frequency doesnt work with HRS.
I use my KO Helios in Advanced High Speed Response mode with my Quantum 2's and KO servos with no problems whatsoever.
i had QC2 + 9550 + HRS in my evo3. No problem, but i ran it in stock profile
Originally posted by AE Racer Like KilRuf said, from othr people experiences, Ive read that the QC2 wont work with HRS in punch control mode 4 because that is the reactive mode and for some reason, the reactive frequency doesnt work with HRS. For some reason I thought all modes (1-5) were reactive freq. Thanks, I'll try it again. |
hey guys, i am using 3PK HRS with a QC2 and KO Propo PDS2343FET digi servo. the servo glitches like mad if i try to turn it when its getting power from the QC2. i solved this by running the reciever with a small battery pack (which weighs my car down heaps :( ) is it only the QC2 that does this to the KO Servo's or do other ESC's do the same. im thinking of getting a novak GT7 to run instead of my QC2 :confused: :confused: :confused: :confused: :flaming: :flaming: :flaming: :flaming: :flaming: :cry: :cry: :cry: :cry: :cry:
i have QC2 + 9550 + HRS in my 415. Profile 4 doesn't work... other than that, everything seems fine.
