Old 04-18-2005, 07:47 PM   #31
imjonah's Avatar
Default this may help
You could mount a stack of 30 pop bottle rockets on the roof, tie there fuses together and then run one long fuse to the motor can.
Just make sure you mount them real secure and have a fire proof pad between them and the Lexan body.
imjonah is offline   Reply With Quote
Old 04-18-2005, 07:56 PM   #32
speedxl's Avatar
R/C Tech Charter Subscriber
oops I guess I read wrong! 96 mph!
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Old 04-18-2005, 08:03 PM   #33
looking closely it was a 2 turn brushless with extremely high gearing
Team_ass.4ever is offline   Reply With Quote
Old 04-18-2005, 08:16 PM   #34
Just get a hacker 6t brushless motor and a shulze u-force speedy. Bolt in heaps of cells and gear as you like. It will be VERY fast and will require very little maintence.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 04-18-2005, 08:59 PM   #35
F1-Fanatic's Avatar
Okay I cannot believe that nobody mentioned this so here it goes... if you want fast and money isn't an object, buy yourself a li/poly battery and a low turn hand-wound motor. The li/poly batteries weigh fractions of the weight of standard nmh cells and produce 12 volts!
With this combination you have a much higher power to weight ratio and a lot more potential.
Just don't think of turning or how many fragments the car will be in when it hits a pebble.
Just my 2 cents...
F1-Fanatic is offline   Reply With Quote
Old 04-18-2005, 09:30 PM   #36
I dont know guys, this sounds like a very costly venture. I think I may end up just getting a nitro TC3 + and do 50mph out of the box.
NormanNormal is offline   Reply With Quote
Old 04-19-2005, 04:01 AM   #37
Top speeds that can be attained very much depends on the room you have. With a 12 turns on the Heemstede track in The Netherlands I have managed to go over 80 Kph (about 50Mph) in a normal 5 minute run despite the fact that the speed trap is only 8 meters before the end of the straight. On smaller tracks 65-70 Kph can be reached quite easily with 12 turn motors. Moreover on smaller tracks the amazing acceleration of electric cars will win out over the sheer speed a gas powered car has to offer.
Tony Vredenberg
tonyv is offline   Reply With Quote
Old 04-19-2005, 06:28 PM   #38
ChadCapece's Avatar
Originally posted by RKeasler
I have done 46mph in a race with a 8 double and 6 cells geared around 8.5-9.0 with a TC3 and yeah 7 cells will fit.
I wonder what track that was at? Sugarbowl maybe
ChadCapece is offline   Reply With Quote
Old 04-19-2005, 06:30 PM   #39
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
You know it!!!!!
RKeasler is offline   Reply With Quote
How to make the E-maxx 16.8v +50mph ?! some help 66006600 Electric Off-Road 7 10-05-2008 08:30 PM
Mamba Max ESC died - can anyone reach Castle Creations? LucentOptics Radio and Electronics 3 01-05-2008 08:56 AM
1/10 electric truggy build. so far so good, but more to come streetracer745 Electric Off-Road 1 05-24-2007 07:02 PM
Most Complicated Electric Truck Build johnbarleycorn Monster Trucks 43 03-23-2005 03:58 AM
reach texbouncer@aol.com ? Lonestar Racing Forum 5 03-07-2004 12:52 PM
SEO by vBSEO 3.5.0
