Old 01-15-2013, 06:50 PM   #31
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
Originally Posted by JFuel11 View Post
Anyone know where you can find the spec tires in stock?
Go on tq and under the tire add your email or request them in stock. As soon as they get in youll be notified fast.
This sounds like a bad ass event, wished natzifornia would have some like that.
TRF-417, KYOSHO SCR-SP
Mr.juarez is offline   Reply With Quote
Old 01-15-2013, 09:04 PM   #32
pigeonfarmboy's Avatar
Uhhhhh http://uf1rc.com/ (depending where you are I suppose) Still one can hop in a car and drive to an event from time to time.
Horizon Hobby
pigeonfarmboy is offline   Reply With Quote
Old 01-16-2013, 05:37 AM   #33
nrtv20's Avatar
Originally Posted by racer034life View Post
Will the new 3racing F113 be out in time for these races. Also what will the track layout be for the race in ohio? I live in ohio and i may go to that race.
I donít know if they will have predetermined layouts for the races; BP might know that answer, but in Toledo currently we change the layout once a month. I would think there would be a special layout just for that race so locals donít have too much of an advantage. But come out and race if youíd like, we run the UF1 rules but limit car width to 180 (mainly to keep it a straight axle class) and we use the Pardus tire as spec. We usually get 12-16 F1ís almost every weekend so there is pretty good competition, come on out and check it out.
http://www.trautengineering.com/ http://www.toledooneeighthracers.com/
http://www.youtube.com/user/nrtv20
One Eigth Racers of Toledo; Hobby Stop West Track; "The Gate" NORCAR
FUTABA 2.4G FASST, Spec-R S1, Speed Passion SP-1, Sakura D3 FWD, Kyosho Evolva M3, Team Losi XX-4, Caster EX1.5R, HPI Wheelie King Crawler, Quanum Aquaholic, Joysway Wildcat
nrtv20 is offline   Reply With Quote
Old 01-17-2013, 05:52 AM   #34
They're back in stock at F1paintlab, $40 with shipping.
I just ordered a set.
AreCee is offline   Reply With Quote
Old 01-18-2013, 07:17 AM   #35
bigcracing's Avatar
Trader Rating: 32 (100%+)
I just bought a F109 with a F104 front end set up. The question is if I buy a set of tires from F1paintlab what rims should I get for it? Are they all the same hex setup? Should I order f104 or 3racing FGX? I will not get the car until next week and I am ordering things for it.
Thanks Chris
bigcracing is offline   Reply With Quote
Old 01-18-2013, 10:14 AM   #36
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Thanks Chris
F103 and F104 are 14mm, they will fit the F109.
FGX and F10 are both 12mm will not fit the F109.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is online now   Reply With Quote
Old 01-18-2013, 10:21 AM   #37
bigcracing's Avatar
Thanks for your help I will put in a order Thanks Chris
Old 01-20-2013, 10:56 AM   #38
bigcracing's Avatar
With my F109 what gearing should I start out with with the 21.5 motor new to me F1
Thanks Chris
Old 01-20-2013, 01:11 PM   #39
I'm running 48p now. I'm running 75/21. If you run 64p, that would be 100/28. It will give you enough room to run from the low 4s to the low 3s/high 2s easily depending on pinion choice.
Old 01-21-2013, 08:59 PM   #40
Did some extensive testing @ Hot Slots this weekend with the 104V2. Got it setup nicely using a combination of Rob K's and the TQ RC setup sheets as a baseline.
Tried both the TCS tires and the Pardus. Pardus glaze over after about 15-20 laps and become a chore to drive. TCS stay perfectly consistant for as long as my 4200mah battery ran. Pretty interesting testing them back to back. May have to try moving my battery further back to try and eliminate build-up on the front tires. Rick Vessel tried them on his F1R with little/no build up.
Horizon Hobby
Old 01-22-2013, 06:04 AM   #41
Default Feb 9/10 Event
After consulting with Brad, we will have a fairly fast flowing layout for you guys on the 9/10, possibly just fliping our current layout end for end.
Team Novak,Gravity RC,
ercwhtsd is offline   Reply With Quote
Old 01-27-2013, 10:46 AM   #42
What time will the Track be open on Saturday and Sunday for the UF1 event?
Old 01-28-2013, 10:39 AM   #43
The Captain's Avatar
Ran the Pardus spec tires Saturday night. Traction rolled all over the track! VERY different from the TCS tires. Never got it dialed in, was VERY difficult to drive. The Pardus tires seemed to be a lot more consistent than the TCS tires though. The TCS tires get progressively worse throughout the run, whereas the Pardus felt the same the entire run.
What helped was running the 1.8 T plate vs the 1.5. Thats as far as I got with it though, still need to make some major adjustments before its even capable of being raced. The 8 min main was long and painful, but I managed to get around the track without breaking anything, which is a win in my book!
-Derrick-
"Yeah, well, thats just like your opinion, man."
The Captain is offline   Reply With Quote
Old 01-28-2013, 11:04 AM   #44
nrtv20's Avatar
Any other cars running the same tire there? Did they have any better luck?
Old 01-28-2013, 11:15 AM   #45
There were three of us that had Pardus tires. One was an older set that was worn in and he did quite well. Mine were new and traction rolled out of the box so I ran a bead of CA on the outside edge of the sidewall and it stopped rolling and ran rather consistant but I suffered from turning late. And then there was the Captain.
Tamiya F104 Pro! NT Electric On-Road 9377 09-05-2017 08:04 AM
FORMULA R/C - Green Bay Parking Lot Racing Howler Wisconsin & Illinois Racing 550 09-08-2015 12:17 PM
MSI Racing and Hobbies: Roseville, Michigan (midwest grand slam) PaintVagrant Racing Forum 26 08-09-2012 09:48 PM
UF1 STILL ALIVE AND WELL! F N CUDA Electric On-Road 117 07-11-2012 11:14 PM
