Old 01-07-2013, 08:27 AM   #1
Default Increase rear traction
Need to get more rear traction. Have 2 ideas but not too sure are the different. Want to know what is the different:
1. Increase the rear toe by +0.5deg
2. Increase the rear track width by 1mm each side.
Both will increase rear traction but what is the different?
ioxqq is offline   Reply With Quote
Old 01-07-2013, 09:31 AM   #2
mkiiina's Avatar
Trader Rating: 68 (100%+)
Might help if you told us what chassis you are running....
mkiiina is offline   Reply With Quote
Old 01-07-2013, 09:33 AM   #3
Increasing rear width will reduce rear traction.
cyclonetog is offline   Reply With Quote
Old 01-07-2013, 11:02 AM   #4
jsinclair's Avatar
Straight line, corner entry/exit, on power, off power. Chassis
jsinclair is offline   Reply With Quote
Old 01-07-2013, 11:35 AM   #5
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Also you might want to add your entire setup, and handling scenarios...because you might have other setup issues and there will be other ways of fixing your traction issues. Droop, roll center, camber links, etc, etc...
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Best way to get more rear traction? Mark _australia Nitro Off-Road 24 03-25-2012 08:52 PM
Xray T2 009 Rubber - Rear Traction problem! ceong Electric On-Road 21 12-27-2011 10:08 AM
Will rasing rear ride height increase rear traction SC10? savannahmick Electric Off-Road 16 02-19-2011 11:24 AM
Need help finding rear traction with my 2.0 Show871 Nitro Off-Road 31 03-23-2010 06:38 AM
SEO by vBSEO 3.5.0
