Old 12-03-2014, 05:23 AM   #91
Default WR8 Top Speed
Originally Posted by fkmliu View Post
I believe the stock setup can run up to 60mph with 3s lipo.
I couldn't hit 60mph with it stocked. There's a guy claiming 70mph but he didn't show any device as proof. These cars are pretty heavy for that 1/10 scale 4000kv motor and their geared for torque not speed. They're good for bashing around. Don't get me wrong they're very quick but it's not doing any speed runs out the box. I upgraded mine to a 1/8 scale system.
ateased1 is offline   Reply With Quote
Old 12-03-2014, 05:25 AM   #92
Not yet, but will post it later, the diffuser also act as a skip plate. buy the diffuser Team Associated Pro Rally Rear Diffuser Set 7172, I got mine from Tower Hobbies, take out the 4 screw from the rear drive housing , measure the hole from the WR8 chassis, re-drill 4 hole on the diffuser, sand down the original countersink to make it flat on the back side of the diffuser, bolt it onto the bottom rear of the chassis, that's it. you might need to trim the diffuser a little to make it fit inside the body.
That's a cool mod! I made my own rear diffuser but I wish I knew about that. Lol!
Old 12-03-2014, 05:32 AM   #93
Originally Posted by Rc1987 View Post
Hello just bought wr8 flux 2013
Was just wondering what top speed has anyone got from one /controllable speed/
Just out of interest?
Well I dab in bashing and speed runs...this car is quick out the box. I'll say it does in the high 50s stock on 3s. I upgraded mine to a 1/8 scale system so I can bash with no heat issues on stock gearing or gear up for speed runs.
Old 12-03-2014, 05:36 AM   #94
MikeGozz's Avatar
Trader Rating: 17 (100%+)
What are the specs you're running? Battery? Motor kv? ESC?
I've been running the Castle Mamba Max Pro with the 3800kv combo, always on 3s. It's an awesome combo, I usually run a 16 tooth pinion but when the weather gets cool I have run up to a 20t and the car just hauls butts!
Here is some video of it rocking the 20t pinion: http://youtu.be/A9noK35tKro
Mike
MikeGozz is offline   Reply With Quote
Old 02-02-2015, 12:23 PM   #95
Really interested in this car. Anyone driven both this and the Team Associated Prorally? I'd assume they are pretty similar for a multi surface basher running 2s on both?
Noize is offline   Reply With Quote
Old 02-13-2015, 09:21 AM   #96
The new livery is on their website as a coming soon for the nitro version. No mention on the electric yet. If they do the car electric with the new livery, I'd wait a few months to get one of those. Looks wicked.
Old 02-13-2015, 09:36 AM   #97
going2fast's Avatar
does the 3800kv set up make a bug difference ? and in what way .. speed/temp/trqu? is it because of its 4pole? what 3800 exactly do you run?sct regular one .. long can? ect .. my wr8 is old and run thre the paces .. I cant find the bearing specs for the stock 4000kv motor so I cant rebuild it and if there is a better motor option im always doen to try it . thanks
5 hpi rs4 rally's /hpi sprint 2 flux/hpi bullet flux hpi firestorm flux/hpi wr8 flux/hpi micro rs4 vaterra glamis uno /axial scx10 g6
team associated sc10b/traxxas 1/16 ken block vxl
going2fast is offline   Reply With Quote
Old 02-13-2015, 10:00 AM   #98
I run a Reedy 550-SL motor. I forget the KV now but it's just as quick as the stock 4000. I changed to that motor purely for the 5mm shaft. I kept chucking pinions and got tired of trying to keep them on. Mod-1 pinion with a 3mm shaft are kinda rare too, so this made finding pinions easier.
MaxxWrecker07 is offline   Reply With Quote
Old 02-13-2015, 10:06 AM   #99
MikeGozz's Avatar
I'm running the Castle 3800 with a 5mm shaft. I originally got it because I kept snapping motor shafts (due to worn drive cups). I'm also using the Mamba Max Pro 1:10 ESC.
I run 3s all the time and the car rips, no over heating, and it eats tires like the cookie monster eats cookies. It is awesome.
Old 02-13-2015, 10:45 AM   #100
MikeR's Avatar
Trader Rating: 15 (100%+)
If you have facebook here's a clip from some epic racing last week at HPI HQ;
https://www.facebook.com/video.php?v...type=2&theater
HPI WR8 Flux/Ken Block H.F.H.V. Rally Car Thread-screen-shot-2015-02-13-10.48.25-am.png
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 02-13-2015, 10:49 AM   #101
going2fast's Avatar
http://www3.towerhobbies.com/cgi-bin...?&I=LXBVYX&P=7
seems like a perfect replacement motor .. 5mm shaft 4000kv and 4 pole .. from what I gather the stock is not 4 pole .. I say that because I don't see it advertised anywhere as such .. and that's something most companies either point out or hid
I think ill try the reedy ..
Old 02-13-2015, 10:59 AM   #102
going2fast's Avatar
I did find that the stock is 4 pole
Old 02-13-2015, 02:31 PM   #103
That's the motor I have. You'll need to extend the wires and get bigger bullets to connect to the ESC. It's a very smooth, cool-running motor, even on 3s. Check EBay for prices, as I think I got mine for around $40 new.
Old 02-16-2015, 07:43 PM   #104
going2fast's Avatar
and you see the same speed from the reedy motor as the castle ...just want to make sure the 550 size motor wont slow it down
Old 02-16-2015, 07:47 PM   #105
I haven't checked it with a GPS, but is certainly seems as fast. The only difference in size was the diameter of the can, not so much the length. I run on 3s, so I'm not certain how it would perform on 2s.
