Like Tree7Likes
Old 01-23-2017, 03:40 AM   #1336
fyrstormer's Avatar
My XV-01 R does 45mph. It's a handful at that speed, but it's a rewarding handful.
If you're going to run on-road, get HPI V-Groove Pro Compound tires. They're the only tires I use for high speeds, because they're properly sticky and they have enough tread that they don't lose all grip once they accumulate a thin coating of road dust.
Check out Fyrstormer's Garage in the Chat Lounge.
fyrstormer is offline   Reply With Quote
Old 01-26-2017, 01:51 AM   #1337
Does anyone know, whether Tamiya or somebody else is selling components that would allow me to create 40mm rear drive shaft? Due to my specific setup, 39mm seems to be a bit short. I've been searching for past couple of hours but not much luck. I can see 3rd party 40mm front shafts, but those have short wheel axle... Thanks!
haplm is offline   Reply With Quote
Old 01-26-2017, 08:58 AM   #1338
firefoxussr's Avatar
Originally Posted by fdjizm View Post
true,50 is plenty for these.
I've got very close with my XV01 and the cheapest 80a/3300kv combo money can buy.
https://www.youtube.com/watch?v=jD_qu_nrMZg
72kph aka 44mph. I didn't push it faster because it was getting really unstable with a undersized 3S in that run.
Parking lot heroes: M06, TA05sw, XV01, XRay T1, SC10B
Partially disassembled: HPI Cup Racer, FGX, M04, TA02, TA05 IFS
Newest acquisitions: A210SS Exige, HPI MX-5, Tamiya F40
firefoxussr is offline   Reply With Quote
Old 01-26-2017, 01:21 PM   #1339
fyrstormer's Avatar
https://www.tamiyausa.com/product/it...oduct-id=53501
These are 42mm CVD shafts. Combine it with the long stub-axle from the 39mm CVD to get what you need.
Old 01-26-2017, 01:22 PM   #1340
fyrstormer's Avatar
Does your body have a wing on it? If it doesn't, add one; HPI has several wing designs to choose from. Pretty much any touring car that goes over 30-35mph is going to need one.
Old 01-26-2017, 02:09 PM   #1341
42mm is too long. I have a spare set of these, which I have already tried, but they bind when the shock is compressed (they hit the back of the outdrive, as they are simply too long). That's why I'm looking for something around 40mm...
BTW - I have also tried one of those adjustable shafts, but that doesn't work either - they are too wide because of the sleeve design, a wait for it - they bind with the outdrive...
Old 01-26-2017, 03:57 PM   #1342
fyrstormer's Avatar
Well, if you know of 3rd-party 40mm shafts, why not just combine them with the Tamiya stub-axles to get what you need?
Old 01-26-2017, 10:20 PM   #1343
I have some doubts that 3rd party shaft will fit the Tamiya stub axle, and since it costs $30, it might be a costly try. But I guess that nobody tried, so I'll have to take the risk.
Old 01-27-2017, 10:12 AM   #1344
fyrstormer's Avatar
They probably made the parts the same size. There's no reason to make them a different size. I think it's worth a try.
Old 01-27-2017, 12:56 PM   #1345
Raman's Avatar
Trader Rating: 56 (100%+)
Looks like the XV01 Long Damper spec is coming back.. It's on the list for the Nuremberg Toy Fair
47349 XV-01 Chassis Kit Long Damper Spec (re-release of 84375)
Raman is offline   Reply With Quote
Old 01-27-2017, 07:00 PM   #1346
Well just in time, I got my Stadium Blitzer body the other day. What length dampers do the xv-01T use in conjunction with the taller damper stays?
4roller is offline   Reply With Quote
Old 01-27-2017, 09:14 PM   #1347
So I'm about to dig into my XV-01 build and want to know if getting a set of titanium hex screws is worth it?
Awallspdx is offline   Reply With Quote
Old 01-27-2017, 09:50 PM   #1348
fyrstormer's Avatar
Eh...titanium is nice, but they're not any stronger than steel screws unless you get super-expensive 6Al4V screws, so the only real benefit would be weight reduction. There are much cheaper ways to shave a few grams off a car; titanium screws are an upgrade that only makes sense if you're building a race vehicle and you've already shaved off as much weight as you can elsewhere.
Old 01-27-2017, 11:04 PM   #1349
What he said. If you want hex screws, get some black steel ones. Stainless hex screws are available too, but they are (like the widely available titanium screws) softer than the black steel variety. Rust and oxidation may be an issue if you are running in wet all day, but should not be an issue with regular maintenance. Worse case, put some grease on threads before threading into any aluminum bits. This chassis is heavy to begin with, so titanium isn't going to net you more than 20g worth of weight savings.
I recently purchased a boat load of steel screws from ebay China. It wasn't a kit. I plan on replacing all my xv-01 and TA05 screws so I bought all the common sizes in bulk. It was a tedious task but you only have to do it once.
Otherwise there are screw kits from "Tony's screws" (heard good things) which boast the black steel screws and also a German company which does the same, and give 50% more screws and hardware in every kit.
Those are pretty much your options for hex screws. But titanium is really just for the races. Money would better be spent on aluminum pullies, metal gear diff, aluminum suspension blocks, and TRF style dampers, carbon reinforced parts.
Welcome to the xv-01! If I had to do it all over again, I'd just repalce really just the carbon reinforced or aluminum suspension blocks, aluminum dampers, and a bag of 3 and 5mm shims. Then replace whatever wears out as you destroy ever piece of rally terrian the xv-01 rolls on.
Old 01-28-2017, 08:16 AM   #1350
Thanks guys, yeah I'm not so much looking for the weight savings as I am for not having to deal with all the Phillip heads. Some of the build forums had people cursing the Phillips screws. Yeah after seeing the price in titanium kits.... no thank you. Thanks for help.
::: Tamiya XV-01 PRO Rally 1/10 Review!!! ::: iluvm4 Electric Off-Road 17 05-04-2017 09:37 AM
Electronics for Tamiya xv 01 highbeam Radio and Electronics 10 12-23-2012 07:56 PM
