Like Tree167Likes
Tamiya XV-01
Old 10-11-2016, 11:44 PM
  #1066
Okay so I went and reamed out the body post holes maybe 2-3mm in the right direction. What a difference! The body really was not that much off. It was basically 2 posts that were too close together that was forcing the body to warp and exaggerate the lopsidedness. Once I added a little slack, the body rests pretty evenly now.
The rear, I can put some 3mm offset rims and/or 6mm hexes to space out to track stance. The front could use a little wider track too, but for now I am satisfied, happy that the body sits straight.
Suspension:
I drove my car around with some high grip radials at low speeds doing sharp turns. Right now I am using yellows up front and silvers in the rear, the third softest and softest springs I have. I will have to tighten up the suspension because the body rolls like a minivan trying to do slalom. Not like the sports car it's supposed to be 😊
I was pressing down on the windshield and wing, with the spring settings I have now and I can guess it won't take much to make the car squat down when driving at even 15-20mph. The bumper makes for a nice rigid backing for the front of the body so it won't bend.
Downforce here I come!
4roller is offline
Old 10-13-2016, 11:01 PM
  #1067
How could you all let the Xv-01 thread get pushed to the second page of On-road Hmm?
There must be someone out there with an active xv-01.
Today I got the 4th wheel of the set of X pattern tires that my friend at work forgot when he gave me the first three. Ha. So now I have a full set. I must say the quality of the rubber is very good compared to the eBay tires I have. The rubber is definitely sticker, and feels a little thicker.
TC suspension:
I may have inadvertantly bid on some TC suspension from a Japanese shopping site called buyee.com. Basically it gives you access to all the Japanese bidding sites and they act as a middleman/broker to get the items shipped from Japan to your residence for a small fee.
It opens a whole can of consumer craziness when it comes to RC stuff now.
I picked up reversible RC suspension, with 44mm CVDs, and xv01TC aluminium suspension mounts for about 1/2 of what I would have spent. The fees can add up though so be careful.
The only thing I will need to get now is the 4x46mm suspension pins for the inner arms. These should be pretty inexpensive and widely available.
The only thing that I have not figured out yet, is how to get the sway bars to work.
Does anyone with a xv-01 TC have sway bars set up? I am pretty sure I can fandangle something with the existing ones. We shall see once all the parts get here. I don't know what this TC setup will get me, hopefully a wider stance and a little more setup options on the front end.
Sigh, papi made me do it 😋
4roller is offline
Old 10-14-2016, 06:00 AM
  #1068
fyrstormer's Avatar
Electric On-Road is pretty active, and the XV-01 is kind of a niche product, so...
That's a nice looking body. Who makes it?
For the XV-01TC, you can use the XV-01 front swaybar and the TA-05 rear swaybar with a small amount cut off the ends.
fyrstormer is offline
Old 10-14-2016, 08:54 AM
  #1069
Thanks. The body is a HPI BMW M3 GT2
Good thing about the sway bars. I would be disappointed if after switching over to TC suspension, that I could not fiddle with sways.
Springs and things
My assortment of springs. Order of stiffness.
[Soft] 4xSilver, Red, Yellow (4xWhite same as yellow), Blue, White [Hard]
I noticed the fewer coils, the stiffer the spring.
4roller is offline
Old 10-14-2016, 08:30 PM
  #1070
Default Tires, tires, tires
Left to right.
Ride Slicks - USGT spec tire 24mm
HPI X-patterns D-compound
eBay Radials (Looks great!)
eBay Leaf Pattern Radials
eBay High Grip Radials
eBay Slicks
The tires with the squarest edges, Ride, Leaf radial, High- Grip radial have excellent corning ability. The ones with a rounder edges, like the x-patterns have only so-so cornering unless your on really clean tarmac.
I have not driven on the new radials, nor the slicks so i can't comment on them. But the new radials look promising.
4roller is offline
Old 10-14-2016, 10:07 PM
  #1071
fyrstormer's Avatar
Yes, the fewer the coils, the stiffer the spring. (assuming the wire is the same thickness.) That's because a spring with fewer coils is made from a shorter length of wire, so each bit of wire has to twist more when the spring compresses.
That's why real cars that have cut-down springs ride very bouncy, because cutting the springs shorter also stiffens them, and the dampers aren't tuned to respond properly to stiffer springs.
Old 10-14-2016, 11:30 PM
  #1072
I am so glad I got a scale RC instead of a SCT with a goofy rally body. The scale realism is awesome. Albeit this is a HPI body and rim set.
Hella flush 😎
These rims are no joke. 6mm offset replica of Work Emotion rims with mirror finish hoops, 7mm hexes on the rear for extra stance.
4roller is offline
Old 10-15-2016, 06:28 AM
  #1073
fyrstormer's Avatar
Those are flush, not hellaflush. This atrocity is hellaflush:
Old 10-15-2016, 06:54 AM
  #1074
Wrong Mr. Fyr, that's onikyan.
@4roller that's flush, to be hella flush the tire must barely clear the wheel well.
30Tooth is offline
Old 10-15-2016, 07:41 AM
  #1075
Just ordered a couple sets of those HPI radials. They have always given me the most traction for my street and the parking lots around here. I use the X-patterns too. They grip just enough to go fast but I can still drift and slide with them.
Love the Work wheels. We used the black ones on my buddy's Supra.
Metal One is offline
Old 10-15-2016, 08:44 AM
  #1076
I am going to have to decorate my workspace. Right now my home shop garage workbench is doubling as rc play station.
Metal One and fyrstormer look like they have nice clean workspaces.
Yes those rims look fly!
I just looked up the HPI v-groove radials. They look mighty similar to the knock-off high-grip radials I have. Not the best durability but great tire for cornering. I am pretty sure the rubber on the HPIs are a little different.
4roller is offline
Old 10-15-2016, 08:47 AM
  #1077
Looks like something you might see at a rc drift meet 😄
4roller is offline
Old 10-15-2016, 08:48 AM
  #1078
Day and night, believe me. I have both, so I can compare. Those no-name tires are only good if you don't care about turn diameter, and unless you don't mind a lot of sliding...
haplm is offline
Old 10-15-2016, 08:49 AM
  #1079
Agreed, flush. When I am in turbo, and my tires are inflated, then it will be hella flush the front barely clears the arches. The rear clears nicely.
4roller is offline
Old 10-15-2016, 09:00 AM
  #1080
The knock-off v-grooves turn much better than the slicks I have. So to me the turn radius is acceptable.
The sidewall deflection is pretty high. Which reminds me that I should try a harder foam custom cut for the sidewalls and soft foam in the center.
The slicks I have produce crazy push going in, and and crazy oversteer coming out of corners. They are pretty much the worst tire for dusty streets. However, they are invaluable tools for tuning purposes, since they exaggerate any imbalances in your car. And it's fun to just smash on them.
4roller is offline
