Like Tree7Likes
Old 01-24-2013, 05:10 AM   #91
More testing
Brushless Or Nothing
dark_luna is offline   Reply With Quote
Old 01-24-2013, 05:25 AM   #92
With brushless, weight is less important. As long as the car is not drastically overweight it can still be competitive.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 01-24-2013, 10:59 AM   #93
stormridersp's Avatar
Originally Posted by dark_luna View Post
More testing
Are you running that overdrive up front?
stormridersp is offline   Reply With Quote
Old 01-25-2013, 06:49 AM   #94
Not in those pictures but I will test overdrive front, rear and without. Don't know exactly how this will affect the car's action
This is a pic of the front overdrive setup with rear 19T pulley
Old 01-25-2013, 08:38 AM   #95
The first drawing may be misleading this is better
Old 01-26-2013, 02:08 PM   #96
Frosty
Old 01-26-2013, 02:25 PM   #97
Raman's Avatar
Trader Rating: 56 (100%+)
Nice, I miss the snow where I live. Planning on heading to mountains for some fun snow Rallye.
By chance, did you check to see if any snow / water got inside the chassis near receiver and esc?
I've noticed that dust gets in there quite easily..
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 01-27-2013, 01:09 PM   #98
No snow or water got inside the receiver and esc housing.
Hehe yes when dusty it's like a vacuum cleaner with the fan connected.
This is more rally, maximum suspension travel 20mm front and 21mm rear
Made some lexan covers
Old 01-27-2013, 05:17 PM   #99
Raman's Avatar
I like your tyres.. What brand are they?
Today I visited this 1/8 scale track. http://revrace.com/
I took my TRF201 and XV-01. I did not have much luck with my TRF201, I'm new to off road buggy and did not have the correct tyres with me. So I decided to run the XV-01.
I ran a 96T with 48T pinion and 17.5. The car was very fast and controllable. I wish I had your tyres, they would have been better for loose dirt. I was running HPI rally, they were pretty good.. As usual with this car, the rear was a little loose at times.
Everyone at the track was "SHOCKED" and so was I! I was able to clear every double jump except for 1 (photo bellow, distance was too far for 17.5 motor). Since its an 1/8 scale track for buggy and truggy, you can imagine the size of the jumps. My XV-01 was sometimes 6 ft / 2 m in the air and it landed 95% of time perfectly. I ran two battery packs and zero broken parts.
Old 01-27-2013, 08:30 PM   #100
Raman's Avatar
Something interesting I learned. The TRF201 guys are running the XV-01 rear hubs, because it has multiple holes to adjust roll centre on camber link. So I assume the opposite is true, we can run the TRF201 rear hubs. The advantage is that they will give us different toe angles. At the moment there is only one XV-01 suspension blocks , so its not possible to vary rear toe.
0 degree
http://www.tamiyausa.com/product/ite...oduct-id=54254
0,5 degree
http://www.tamiyausa.com/product/ite...oduct-id=54245
1,0 degree
http://www.tamiyausa.com/product/ite...oduct-id=54246
Camber link adapter, gives additional options for changing roll centre
http://www.tamiyausa.com/product/ite...oduct-id=54405
Old 01-28-2013, 01:14 AM   #101
Dark Luna
Did you at the start, bend the Novak motor solder tabs up to make them straight in order to clear the plastic motor cage?
I'm about to start my Xv-01 build too, and really wanted to put a 10.5 Novak on. Not sure if it will fit with those tabs on the back.
Forgetful_Duck is offline   Reply With Quote
Old 01-28-2013, 03:41 AM   #102
That is impressive indeed. I had the preconception that the front motor chassis would be totally unbalanced for jumping.
Old 01-28-2013, 03:44 AM   #103
Originally Posted by Forgetful_Duck View Post
Dark Luna
Before you start assembling it, may I ask you a favor and weigh up the main chassis part?
thanks
Old 01-28-2013, 05:03 AM   #104
I've had my Kit since July 2012 (last year) and it's still sitting inside its freight box unopenned...
I'm only starting to gather up the electrics for it as I've put other RC projects infront.
I don't think I'll be opening the kit until about 3-4 weeks from now....
thanks
Old 01-28-2013, 10:44 AM   #105
Raman's Avatar
Dark Luna
This is how I installed the ballistic in mine
Tamiya XV-01
Darkluna took a different approach, I'll leave it to him to explain.
::: Tamiya XV-01 PRO Rally 1/10 Review!!! ::: iluvm4 Electric Off-Road 17 05-04-2017 09:37 AM
Electronics for Tamiya xv 01 highbeam Radio and Electronics 10 12-23-2012 07:56 PM
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
