Like Tree19Likes
Old 05-13-2016, 05:44 AM   #781
A little too late now. Sounds like something Tamiya needs to be called out on. Nobody should pay more for worse performance.
My hovercraft is full of eels.
Metal One is offline   Reply With Quote
Old 05-13-2016, 06:49 AM   #782
I wouldn't worry about what fyrstormer said about the front carbon damper stay twisting. The FF04 Evo uses much longer standoffs on its carbon front damper stay, yet you don't see people complaining about it
breyton is offline   Reply With Quote
Old 05-13-2016, 07:18 AM   #783
firefoxussr's Avatar
Originally Posted by Raman View Post
The man at Killerbody must be my long lost Alfisiti brother, because only he would release this!
http://www.killerbodyrc.com/page/new...x?cate=2&id=52
Oh my..... I've been dreaming up how to make a Tipo 33 Stradale for like two years.
And an Alfa SZ, now that's hardcore Alfa.
Parking lot heroes: M06, TA05sw, XV01, XRay T1, SC10B
Partially disassembled: HPI Cup Racer, FGX, M04, TA02, TA05 IFS
Newest acquisitions: A210SS Exige, HPI MX-5, Tamiya F40
firefoxussr is offline   Reply With Quote
Old 05-13-2016, 05:17 PM   #784
Well... either way, we'll see. Not too big of a deal, really. I still love the XV-01 It's just the best thing ever! I'll be real familiar with the gearboxes after swapping those pulleys for a second time. Oh, that'll be a good time to do the reinforced belt and that aluminum front hinge pin bracket too. Still don't have CVD's. I guess those will be next and that should just about do it for mine. There's an aluminum steering bellcrank but I really don't see the need for that. All cars should have steering systems this good.
Old 05-13-2016, 06:45 PM   #785
fyrstormer's Avatar
The FF-04 is generally driven on much smoother surfaces, where the effect is less apparent.
On my rear-motor converted XV-01, I had a hell of a time getting the rear suspension to stop bouncing. I was all the way up to 2000wt oil in the rear shocks before I figured out it wasn't the shocks that were rebounding too fast, it was the rear shock tower (which had the front standoffs mounted to it as part of the conversion). When I replaced the carbon-fiber shock towers with the carbon-reinforced-plastic shock towers, the problem vanished.
I'm not saying anyone else will necessarily *care* about it, but it does happen.
Check out Fyrstormer's Garage in the Chat Lounge.
fyrstormer is offline   Reply With Quote
Old 05-13-2016, 06:47 PM   #786
fyrstormer's Avatar
Wow. That body looks amazing. And they come pre-detailed?
Old 05-19-2016, 01:36 PM   #787
So close to completing my Stratos. My star wheels are here and painted yellow. The 2mm and 10mm offsets are going to be perfect for it. The Pirelli rally tires SHOULD have been here today but they didn't make it. Hopefully, they will be here tomorrow. The body posts have been cut down for the Stratos so no more Delta without installing new posts. I've designed, printed and cut the rest of the decals needed to complete the livery. I even made new window decals because the ones it came with were ugly. I'll apply those tonight after work. I was really hoping those tires would be here today.
Got all of the aluminum and CF goodies installed and finally replaced that spare plastic rear A-arm from the first big crash with a carbon reinforced one. Love how those aluminum pulleys look with the gold teeth. Too bad they can't be seen under all of the covers but I'd rather them be protected anyway.
In other news, I got a set of MIP speed tips for my new Hammerhead cordless screwdriver that I got on sale last week for $20. The bits cost twice as much as the screwdriver but a good set of MIPs is worth every penny.
Old 05-19-2016, 01:50 PM   #788
fyrstormer's Avatar
They sure are. I love MIP drivers.
Old 05-20-2016, 04:17 PM   #789
The Stratos.
Tamiya XV-01-stratos1.jpg   Tamiya XV-01-stratos2.jpg   Tamiya XV-01-stratos3.jpg   Tamiya XV-01-stratos4.jpg
Old 05-20-2016, 04:43 PM   #790
angrymelon's Avatar
Turned out pretty awesome!
-=Ryan B=-
VBC Racing USA - Team Powers USA
PDX On-road: https://www.facebook.com/groups/onroadracing/
angrymelon is offline   Reply With Quote
Old 05-20-2016, 05:25 PM   #791
Thanks. I was so unhappy with the way it looked when I first got it. The crinkled corners, lack of detail and no included livery decals was pretty disappointing after 30 years of Tamiya and HPI bodies. It didn't get much better after painting it white.
That has all changed now!
Old 05-20-2016, 07:56 PM   #792
fyrstormer's Avatar
Wow. You cleaned that sucker up good. But now how are you going to run it?
What did you have to do to clean up the body? It sounded like a real hack-job when you got it.
Old 05-21-2016, 11:35 PM   #793
fyrstormer's Avatar
After searching high and low for bodies with short-enough noses to fit behind the hard bumpers used on the XV-01T Asterion, I gave up and bought another Lancia body to put on my XV-01 FF:
Now I have a matching set.
Old 05-22-2016, 06:22 AM   #794
Well, it is a great looking body. The wider tires give it a little meaner look.
Most of the flaws are still in my Stratos body if you look close enough but white paint, decals and good camera angles hide many things. It won't be entering any Concours shows any time soon but it'll be great for bashing. I glued the new tires on last night and it's ready to run this morning.
Edit. First run with new setup went well. Those HPI Pirelli's, man! With the extra grip and the wider rear track, the steering is crazy fast now. Still handles great. Doesn't slide as much and hangs the turn a bit faster so cutting or going wide could be trouble. Gotta nail that line. Going out for some video later.
Old 05-22-2016, 01:55 PM   #795
fyrstormer's Avatar
They are great tires. The D-compound tires slide better than the S-compound tires do, but obviously that means they don't track as well when you want to corner cleanly.
::: Tamiya XV-01 PRO Rally 1/10 Review!!! ::: iluvm4 Electric Off-Road 17 05-04-2017 09:37 AM
Electronics for Tamiya xv 01 highbeam Radio and Electronics 10 12-23-2012 07:56 PM
