Old 01-07-2014, 07:57 PM   #466
Honestly this is my first ever onroad chassis. Prior I had only owned trucks. I am not really sure of "a good ratio" I think it depends what you want to do. Research tells me smaller ratios are good for big open tracks with long sweeps and big ratios eg 1.6-2+ are good for technical stuff and also give a more realistic counter-steering look. Starting at 50/50 was a great way to improve my newb skills but i found it much more fun drifting around the kitchen table legs at 1.25. Can't wait to try 1.5 and hopefully higher.
You can find the 3racing pulleys on ebay and RCmart and probably many other places. RCMart has them listed as "T20 Pulley" etc not 20t pulley for some reason so try that in the search if you cant find them.
In regards to the universals you are right, 46mm would have been much better. I plan to try out the active hobby adjustables (43-53mm) eventually. Bit over the money pit for now though and will hold off on them until I need to order something else.
PS: the XV-01 TC seems to use the same arms, knuckles, c-hubs as the ta-05 and a few other tamiya cars. This which helped a lot when sourcing parts and should mean the width is the same as stock.
icekreme1002 is offline   Reply With Quote
Old 01-07-2014, 09:14 PM   #467
Raman's Avatar
Trader Rating: 49 (100%+)
Originally Posted by stormridersp View Post
They did and won the Corsica Rally in the late 80s against the Lancias. As far as I remember, BMW rally cars were prepared by Prodrive, the same racing factory that prepared all the winning Subarus.
http://en.wikipedia.org/wiki/Bernard_B%C3%A9guin
Stormrider, good to hear from you man.. I am back in Southern California! When are you coming for a visit? Lets go to Mammoth for some XV-01 snow rallye
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 01-08-2014, 10:03 AM   #468
stormridersp's Avatar
Oh man! I wish! Actually I was a planning a trip to Tahoe in March, but it went to the drain man, so it wont be this time Im afraid. But Ill do my best to go maybe next winter or summer.
How things going there in paradise my friend?
stormridersp is offline   Reply With Quote
Old 01-09-2014, 02:04 PM   #469
Default First Hobby Grade RC Car
Hey Guys,
After getting an HPI Micro RS4 Block for Christmas I decided to get a hobby grade car. Maybe this is crazy for my first RC Car but I have an XV-01 on order from my LHS. Just wanted to say I've enjoyed reading the thread and look forward to building it and being a member here.
silentgiant is offline   Reply With Quote
Old 01-10-2014, 09:38 AM   #470
Raman's Avatar
Things in paradise will be fantastic as soon as I find a job! lol. Otherwise its good....
Old 01-13-2014, 02:17 AM   #471
clittle's Avatar
Yeah, it got a bit dirty.
It's all clean now, but I do have a problem with things getting into this part of the car. I've noticed some people using bicycle tyre tubes to extend the protectors. I'm thinking I'll need that too.
I ran it in my local park today and it got stones in the steering and in-between the front drive shafts and the suspension arms. Made quite a racket.
Other than that, when there is no obstruction, this handles great. I really like the front spool on dirt. You point, shoot and it goes where you want.
Latest is a Tamiya TB04 Pro..... Love it!!!
Aussie in Japan!
clittle is offline   Reply With Quote
Old 01-18-2014, 05:49 AM   #472
clittle's Avatar
Default Cleaned, dried and out we go again.
I took it out again today. This track is used mainly for 1/8 buggies and it's bumpy! I think I need to remove some steering though. It shoots left and right very, very quickly.
Aussie in Japan!
Old 01-22-2014, 02:19 AM   #473
Default Check out 3 racing
The other day my front weels went into full lock again. In that case I bought universal shaft 42 mm for Sakura zero. As well for the axls arms. I'm going to check out other parts today. Suspension arms etc... Does anyone have tried anything? Pictures will come later (if they fits)...
frodepv is offline   Reply With Quote
Old 01-22-2014, 11:36 AM   #474
shmit 1's Avatar
I had the same problem with the steering binding. I used a dremel to remove some material from the c-hub. It would rub the the drive cup when turning. I am still using dog bones.
shmit 1 is offline   Reply With Quote
Old 01-25-2014, 02:54 PM   #475
spring71's Avatar
Smile
XV-01 hopups and spares are available at TQ.
http://www.tqrcracing.com/shop/parts...arts_p_id=7215
FYI, Thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
tq@tqrcracing.com
spring71 is offline   Reply With Quote
Old 01-29-2014, 09:11 PM   #476
Kigoma's Avatar
Little surprise on Tamiyablog...
Kigoma is offline   Reply With Quote
Old 01-30-2014, 03:47 PM   #477
Raman's Avatar
So we now have long damper stays to be used with buggy springs. But then it says the kit comes with the CVA Mini dampers?
Old 02-01-2014, 02:20 AM   #478
Default Newbie need help on xv-01 tc pro
Hi all,
M a newbie in rc, recently gotten a 2nd hand xv01 tc
However there is a problem with the car, when my Tx is on N.
The car is running reverse when trigger is squeezed and when Tx turned left the car actually turn right.....
Everything is reversed, so I have to put to R for both throttle n Steering for it to operate as per normal however....
I am using tamiya stock fine spec Tx n teu105bk n tru-08 I have check the wire should b right
Have try reset but still not getting right.
Advise is appreciated
Ty in advance
wilron is offline   Reply With Quote
Old 02-03-2014, 03:25 PM   #479
CVA Mini are used as front shocks on Tamiya buggies, this is OK.. But I don't get why they made new daper stays, I thought that CVA mini fit on XV, since XV01T got them?
Papi is offline   Reply With Quote
Old 03-30-2014, 08:17 PM   #480
ThePanda's Avatar
Trader Rating: 64 (100%+)
I just ordered one of these cars, any tips?
ThePanda is offline   Reply With Quote
::: Tamiya XV-01 PRO Rally 1/10 Review!!! ::: iluvm4 Electric Off-Road 16 01-30-2017 11:20 AM
Electronics for Tamiya xv 01 highbeam Radio and Electronics 10 12-23-2012 07:56 PM
