Old 11-11-2013, 08:39 AM   #436
Originally Posted by Raman View Post
Manual says rod stopper available separately? Including 3 little pieces of blue aluminium would have killed them?
I agree with you!
please help! I have an issue I'd like to show, but I can't. it's in a album. what do I have to do? thanks! Rob
xv01disapp is offline   Reply With Quote
Old 11-11-2013, 12:46 PM   #437
metalnut's Avatar
Trader Rating: 36 (100%+)
Originally Posted by xv01disapp View Post
I agree with you!
I don't follow.. is your problem related to the rod stoppers? I just bought some Spec-R ones, they work as expected.
Team Nervous | Team Scruffy | Team Orange
"If you ain't first, you're last!"
- Ricky Bobby
metalnut is offline   Reply With Quote
Old 11-12-2013, 09:36 AM   #438
Hi!
No, it's a problem with the part NN24 of the kit. It is a part of the pulley. There should be two of them, but one is "fat", as if it wasn't totally worked (sorry for my English...). I have the photos in the album. I'll try to put them in this reply.
In my profile there is a larger explanation. Thanks!
Rob
Old 11-15-2013, 05:46 AM   #439
Smile's Avatar
I'm not entirely sure what you mean but, one is "fat" because NN3 is on top of NN24.
Smile is offline   Reply With Quote
Old 11-15-2013, 01:53 PM   #440
Dear Smile...you are quite right!!!
OMG, I didn't notice it! Thank you very very much!
Rob
Old 11-16-2013, 07:58 AM   #441
Smile's Avatar
No problem! Just ask anytime
Old 11-24-2013, 06:33 AM   #442
Raman's Avatar
Trader Rating: 47 (100%+)
Well my stay in Brazil is coming to an end. Tuesday I head back to Los Angeles. I brought with me one RC car so that I could have something to do, the XV-01. Every time I made plans to run it, I either forgot a screw driver to open the battery hatch, or battery was bad etc.
So yesterday I told my wife, I am determined to use this damn car before we head back. I convinced her to drive with me to a track 40 min north of Porto Alegre, where we are staying. This is the track that they hold the brazilian championships at, so its quite large.
When I arrived there were 3 guys running 1/5 FG cars. I kind of felt embarrassed showing up with a 1/10 scale. Anyhow, I dropped the battery in and did a warm up lap and decided to unleash the 17.5 with 20 timing and boost. After they saw my XV-01 storm down the front straight, they were impressed with its speed LOL.
At first I was perplexed why it wanted to roll over in turns, so I brought it in and realised it still had the long shock ends installed for dirt gravel and changed them out for the short ones. Put the car back on the track and it became extremely planted.
Later in the day, I switched out the 17.5 with a Vulacan Outlaw 10.5! (yes I am nuts) Since I did not have my computer, I left the timing on, but I dropped down in gearing to stock spur with 21T pinion. The car was a bullet down the straight, however the timing trip points where set for 17.5, so it was driving like an on / off switch in the mid field.
I initially was using my beat up BMW M3 body with Sorex 36R slicks. I later switched to the Tam's Toyota GT86 body.. the car started to handle even better.
I wanted my wife to take a video while I went around the track with the GT86 body, but she had her hands full with our newborn. The 1/5 scales were making too much noise for him to fall asleep after being fed. So once again I fail at proving a video.
Now that I am heading back, I will definitely use the XV-01 to race in a 3rd class, along with my 416 and M06.. its much more forgiving than my TRF416 to when it comes to set up.
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 12-08-2013, 11:01 AM   #443
I'm looking for a new motor/esc-combo for my XV-01 Pro. Should I go sensored or sensorless and what's kind of EScs do fit the XV-01 best?
muesli is offline   Reply With Quote
Old 12-08-2013, 11:29 AM   #444
Raman's Avatar
Sensored is always better. They offer more precise control, especially at low speeds. My ESC's are all Novaks.. the small ones like Edge, Impact and Club will fit with ease. Larger ones like Havoc Pro, GTB, Pulse will need some trimming to fit.
Old 12-08-2013, 11:49 AM   #445
Thank you. I think I'll buy the Club Spec. There are three more questions:
1: How smooth is this ESC in sensor less mode, which I will have to choose for racing on Ice and snow. This might be quite important, because I'm living in Switzerland at the moment
2: Where can I get a sensor wire, which is long enough to fit the XV-01?
3. Which of motor would you choose? I think about 2500-3000KV are fast enough, but which is the best off road-proven one?
Old 12-08-2013, 11:59 AM   #446
Raman's Avatar
The Novak ESC only run in sensor mode. I have driven mine on ice and snow and it works great in sensor mode as well. So you will not have a problem.
Sensor cable: Tamiya has released their own sensor cable (54381) for cars like the XV-01. Its 35 mm long! Works great for the XV-01
http://www.tamiyausa.com/items/radio...or-cable-54381
For off road, I believe a motor between 2500 to 3000 kv is sufficient. If you plan on a Novak club system, the equivalent would be a 17.5 motor.
Old 12-08-2013, 12:41 PM   #447
The Novak ballistic in 17,5 has 2200KV, so the 13,5 with 3300Kv might be better, because i would to keep the speed it has at the moment.
Currently I'm running a GM Genius 75 ECS, which is taken from my F104, with an old Team Orion Motor taken from Vortex Experience off road edition brushless combo, but I can't find how many KV it has...
Old 12-08-2013, 12:49 PM   #448
ThePanda's Avatar
Trader Rating: 62 (100%+)
I disagree with sensored always being better. For most bashers it is just one more thing to worry about. Sensor less is more efficient, so many escs will switch to sensor less mode when the motor spins up anyways.
ThePanda is offline   Reply With Quote
Old 12-08-2013, 01:19 PM   #449
Raman's Avatar
Sensorless is more efficient? Disagree, its more economical for bashing yes. Many bashers eventually get bored of bashing (including myself) and decide to show up to a club race and end up needing to buy a sensor system, after they watch their cars cog when they try to get going. So why not do it right from the get go and save money.
One more thing to worry about? Its a wire, you plug it in and its connected. Without sensors you have to deal with cogging constantly.. cogging is far more inefficient than a hall sensor.
The inefficiency myth was created by Castle Creations to justify their ESC / Motors not having one. Sensored ESC switches to non sensor mode because once the rotor has passed its initial starting point, it is not necessary to know its position. Castle eventually ate his words and now sells sensored ESC as well.
Old 12-08-2013, 01:20 PM   #450
Raman's Avatar
I have run 17,5 13,5 and 10,5 in the XV01. It handles all quite well. Just be mindful of gearing when using 13,5 and 10,5 off road.
::: Tamiya XV-01 PRO Rally 1/10 Review!!! ::: iluvm4 Electric Off-Road 14 01-16-2014 07:00 PM
Electronics for Tamiya xv 01 highbeam Radio and Electronics 10 12-23-2012 08:56 PM
SEO by vBSEO 3.5.0
