Old 01-09-2013, 05:01 AM   #31
Great info Raman
There's also
#54450 18T Aluminum Pulley
#54448 Reinforced Drive Belt 573mm
Cut holes in the grill for more cooling
Brushless Or Nothing
dark_luna is offline   Reply With Quote
Old 01-09-2013, 03:26 PM   #32
Raman's Avatar
Trader Rating: 48 (100%+)
I just received the reinforced belt.
TamiyaUSA has a whole list of hop ups coming.. All the parts will be available in carbon reinforced plastic. Also carbon fibre front and rear shock towers are coming. There is also dirt tuned springs.. I'm assuming they are longer springs and softer
Nice work on the grill, I thought of doing the same. Even though the motor is up front, there is little air circulation.
Have you noticed that the covers for th esc and receiver act more like a vacuum than a dust cover. Lol everything i run the car in dirt, I open it up and there is dust in there. Im contemplated installing fans running in reverse to blow it all out
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 01-09-2013, 03:46 PM   #33
Raman's Avatar
The following are my build Picts from last August
Here are before and after picts of motor mount last. I resolved the motor tabs different then dark Luna.
dremeled off about 2 mm
Here is how I had mounted my switch (now it's on top of servo)
Lancia Delta Body being prepped The DF03 version with pre-marked posts line perfectly up, no guess work
I have to say, the drive train on this car is really smooth! Nice to have a belt driven rallye car.
Initil set up the car as follows for now:
Front diff 5000 cs
Rear diff 1000 cs
Front dampers 50 weight, yellow spring (white with yellow mark)
rear dampers 35 weight, red springs
Front camber -1º
Front toe out 1º
Rear camber -2º
Rear toe: stock kit
Here are picts of my Lancia Delta Integrale with driver figures to boot. Note: front bumper was trimmed considerably to fit body.
Old 01-09-2013, 10:41 PM   #34
DangerCow's Avatar
I'm new to on-road stuff, and wondering what bodies fit this (and how to tell if a body fits). I really dig the Kyosho Lancia Stratos body, but $80 at AMain?
Any ideas of something similar from someone else?
___________________________________________
Axial Scorpion; Exo ../.. Kyosho Turbo Ultima; USA-1
Schumacher CAT K1; Cougar sv2; Cougar KF ../.. Serpent 411 ERYX 2.0
Tamiya XV-01 Pro ../.. Team Durango DEX210; DEX410; DEX408v2
Yokomo B-Max III Factory www.corvictoria.com
DangerCow is offline   Reply With Quote
Old 01-09-2013, 10:59 PM   #35
Raman's Avatar
The Kyosho stratos will not fit this car. Its a considerably larger scale car. Kyosho calls it 1/9 scale.
For a car like this... this is the stratos body that will fit
http://rallylegendsrc.com/index.php?...tegory&path=69
Old 01-10-2013, 02:47 AM   #36
Djioul's Avatar
VERY nice looking car !
I'm looking to order an XV-01 pro, and if I do, for sure I'll get a lancia body, so good to remember these great times when Sainz and Auriol were putting it to the limits in the 90's !
Did the drivers stiff comes from Tamiya or is is from another brand?
Losi SCTE Ten - hobbywing 120A - Ezrun 2800kv
Lazer ZX5 - hobbywing 120A - LRP 6.5T
Schumacher cougar mk 1 - hobbywing 60A - Orion 10.5T
Tamiya M03 & M04M - both with TEUBK 101 - Mabuchi 540
Nikko dictator II full stock... for the moment.
Djioul is offline   Reply With Quote
Old 01-10-2013, 07:48 AM   #37
That Lancia looks great Raman!
Cut the lower grill
Getting closer to 1500g
Old 01-10-2013, 07:57 AM   #38
stormridersp's Avatar
Easy. The bodies that will fit are mostly 190mm width and 257mm wheel base.
stormridersp is offline   Reply With Quote
Old 01-10-2013, 08:04 AM   #39
Cut the lower grill
[IMAGES]
You´re poking a lot holes up front! I would say its a good idea to poke a few holes on the rear windscreen too so to reduce the parachuting effect created by the increased flux of air inside, reducing you downforce and increasing your drag.
Old 01-10-2013, 09:53 AM   #40
Raman's Avatar
Its from Tamiya.. this is the part number of the two man cockpit 1825096
They also have single driver left and right hand drive
54298 Cockpit left hand drive (single)
54157 Cockpit Right hand drive (single)
Old 01-10-2013, 10:43 AM   #41
Djioul's Avatar
Thanks for the P/N, I'll have to put one of these in the basket once I'll be decided for the pro kit.
Old 01-10-2013, 12:36 PM   #42
DangerCow's Avatar
Would the HPI BMW M3 GT Touring Car Body (190mm) fit the XV-01? Is the wheelbase of the car (257mm) the same as touring cars?
And is the XV-01's 12mm hex the same as a typical touring car?
Thanks again for the help!
Old 01-10-2013, 12:59 PM   #43
ngo8's Avatar
Send a message via ICQ to ngo8
don't know about the body but the wheel hexes are same as regular touring cars .
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 01-10-2013, 01:05 PM   #44
Sith Lord's Avatar
Trader Rating: 21 (100%+)
As stormrider said, pretty much any 190mm body with a 255-258 Wheelbase will fit. The one thing to look out for though is large bulging wheel arches. If it's not a perfect fit and you have to cut the arches in a different position then it might look silly. You shouldn't have that problem with the M3.
Tamiya XV-01 Rally :: Tamiya FAV 2011 :: Proline Pro2 SCB
Sith Lord is offline   Reply With Quote
Old 01-11-2013, 01:03 AM   #45
kentech's Avatar
Official photo of the TC kit to be released February.
58558 XV-01TC PRO Chassis Kit
http://kentech.blogs.se/
kentech.wordpress.com
kentech is offline   Reply With Quote
::: Tamiya XV-01 PRO Rally 1/10 Review!!! ::: iluvm4 Electric Off-Road 16 01-30-2017 12:20 PM
Electronics for Tamiya xv 01 highbeam Radio and Electronics 10 12-23-2012 08:56 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
