Old 09-22-2013, 01:06 PM   #421
Raman's Avatar
Trader Rating: 48 (100%+)
Originally Posted by stormridersp View Post
Here's my XV-01 PRO; hope that you guys like it.
You missed a spot... the stabilizer rod ends aren't blue
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 09-22-2013, 04:55 PM   #422
stormridersp's Avatar
Lol!!
Good eyes! I had these already assembled from my previous TA-05' sway bars adaptation. When I remembered how painful it was to precisely cut those tiny ball joints and then assemble them together; Id said nay, better leave it like this!
stormridersp is offline   Reply With Quote
Old 09-23-2013, 08:16 AM   #423
SerpentCT4S's Avatar
Trader Rating: 94 (96%+)
Send a message via AIM to SerpentCT4S
stormridersp - Nice chassis!
Do you have part number for the aluminum hexes and aluminum suspension mounts? I've seen they have a few different ones. Which ones do I need?
SerpentCT4S is offline   Reply With Quote
Old 09-23-2013, 11:16 AM   #424
Thanks man!
The parts are:
Blue Hexes: Tamiya (#53570) Clamp Type Alu. Wheel Hub (4mm Thick)
http://www.rcmart.com/tamiya-53570-c...h=595_744_1561
Suspension mounts:
-Tamiya XV-01 Aluminum Suspension Mount XJ #54379
http://www.rcmart.com/tamiya-xv01-al...h=595_744_1561
Tamiya XV-01 Separate Suspension Mounts (1XJ) #54376
http://www.rcmart.com/tamiya-54376-x...h=595_744_1561
Tamiya XV-01 Separate Suspension Mounts (1XM) #54377
http://www.rcmart.com/tamiya-54377-x...h=595_744_1561
Old 09-23-2013, 12:53 PM   #425
What are the differences in the 3 different mounts?
Old 09-23-2013, 01:37 PM   #426
metalnut's Avatar
Trader Rating: 36 (100%+)
You actually need all three. The long one is used front and back (if I recall), with the small ones being used for the other side of the pin, one set for the front, the other (different) set for the back.
Team Nervous | Team Scruffy | Team Orange
"If you ain't first, you're last!"
- Ricky Bobby
metalnut is offline   Reply With Quote
Old 09-23-2013, 04:03 PM   #427
Raman's Avatar
Lol!!
Which Novak ESC are you running? Havoc Pro SC?
Old 09-23-2013, 04:13 PM   #428
Raman's Avatar
Correct.. the one piece (1XJ) is used for front and rear outer. The separates, 1XM is for the rear, and 1XJ for the front.
My guess is that the 1XJ / 1XJ combo in front gives 0 toe and 0 arm sweep in front. The 1XJ / 1XM in the rear gives 2.0 - 2.5 toe in? .. never measured it.
Unlike the TC version that uses that TRF/TB/TA mounts, the XV mounts give us limited suspension angle tuning.
Old 09-23-2013, 04:52 PM   #429
Sith Lord's Avatar
Trader Rating: 21 (100%+)
Yeah Racing make a set too. A bit cheaper than the Tamiya versions. Not sure if they have more combos?? Edit... No they don't. Just the regular set.
Tamiya XV-01 Rally :: Tamiya FAV 2011 :: Proline Pro2 SCB
Sith Lord is offline   Reply With Quote
Old 09-23-2013, 05:02 PM   #430
Im using the regular GTB2 w/X-Drive.
Old 09-23-2013, 05:50 PM   #431
metalnut's Avatar
I'm really happy with the Hobbywing Justock in my XV, it's small and super smooth, and sensored to boot!
- Ricky Bobby
Old 10-23-2013, 05:58 PM   #432
Raman's Avatar
Earlier this year, new RC brand carisma displaced an 1/8 scale Porsche 959 in rothmans Dakar livery.. Fully licensed. Every once in a while I try to check for info on it and usualky nothing new comes.
Today I saw a body set for it, however it says 1/10 scale. It's a possibility since they presently have an Audi Quattro Rally body. So I do hope it's true
Old 10-24-2013, 12:19 AM   #433
Only problem is that the Tamiya 959's wheelbase is closer to the SWB Mini..
jjjheimer is offline   Reply With Quote
Old 10-24-2013, 03:46 AM   #434
Raman's Avatar
This isn't produced by Tamiya.
Old 11-11-2013, 08:28 AM   #435
Completely agree with you!
xv01disapp is offline   Reply With Quote
::: Tamiya XV-01 PRO Rally 1/10 Review!!! ::: iluvm4 Electric Off-Road 16 01-30-2017 12:20 PM
Electronics for Tamiya xv 01 highbeam Radio and Electronics 10 12-23-2012 08:56 PM
