Like Tree5Likes
Old 09-05-2013, 07:46 AM   #361
stormridersp's Avatar
Originally Posted by metalnut View Post
If you look in this and the rally thread, you'll see YouTube videos of our friends in the EU who have organized rally races. I think most of them are in... Romania, if I remember correctly? They have some awesome cars and awesome tracks set up, nothing like that exists here in the U.S. I've been trying to get some local rally interest going, but pretty much nobody seems interested. Very sad.
I believe its Czech Republic, not Romania.
There are some guys who rally in Colorado, from time to time they post up some vids. They race against each other like Rally Cross, on narrow tracks, jumps and tight turns.
You can find them at RCcralwer forums, which has a special Rally section.
Here in Brazil is pretty much impossible to find some rally lovers. Everybody are either into extreme nitro on-road pro racing or extreme jumping and crashing off-road. So most of the tracks are either way too fast or way too jumpy. Those who like bashing, they all have some crazy ultra nitro hardcore butt ugly big foots.
stormridersp is offline   Reply With Quote
Old 09-05-2013, 01:56 PM   #362
metalnut's Avatar
Trader Rating: 36 (100%+)
Oh, right, thanks for correcting me!
I'm still hoping that I'll find some local interest here. I mean.. it's so much fun!
Team Nervous | Team Scruffy | Team Orange
"If you ain't first, you're last!"
- Ricky Bobby
metalnut is offline   Reply With Quote
Old 09-06-2013, 03:59 AM   #363
foampervert's Avatar
Send a message via MSN to foampervert
Default My favorite rally body, how to make it fit?
Hiya folks,
The datsun 240z rally shell from tamiya is my favoritest rally shell.
How can I make it fit a xv-01 chassis?
Any suggestions?
-Alexander
During heats, i use durex for both front and rear, with Hard inserts.
Sorex, i meant Sorex.
foampervert is offline   Reply With Quote
Old 09-06-2013, 08:25 AM   #364
Raman's Avatar
Trader Rating: 54 (100%+)
You should not have any problem fitting it. It's a standard 190mm body
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 09-06-2013, 01:48 PM   #365
metalnut's Avatar
You think so? I've been drooling over it, but was worried it wouldn't fit right over the front motor
- Ricky Bobby
Old 09-06-2013, 01:53 PM   #366
Raman's Avatar
If the Toyota FT86 fits, so should the Z. Its based on a car with a front engine. The only bodies that will be a tough fit would be mid engine, like an NSX, Ferrari etc.
Old 09-06-2013, 01:57 PM   #367
metalnut's Avatar
You're the reason my credit card bills hurt
- Ricky Bobby
Old 09-06-2013, 03:59 PM   #368
Raman's Avatar
My mother always said I could never save even a penny.. since I can't do it.. i might as well make others be just like me
Old 09-06-2013, 07:36 PM   #369
Im just like you!
I have no complains!
Old 09-06-2013, 09:51 PM   #370
Sith Lord's Avatar
Trader Rating: 21 (100%+)
Originally Posted by foampervert View Post
Hiya folks,
Any suggestions?
-Alexander
Do you have the body? How do you know it doesn't fit?
Tamiya XV-01 Rally :: Tamiya FAV 2011 :: Proline Pro2 SCB
Sith Lord is offline   Reply With Quote
Old 09-07-2013, 01:00 AM   #371
IAmGreatDane's Avatar
What about the wheelbase? The Datsun is, I believe 251 mm, while standard wheelbase are 257 mm.
Is possible to alter the wheelbase on the XV-01 using spacers?
Best Regards,
I Am GreatDane c'',)
IAmGreatDane is offline   Reply With Quote
Old 09-07-2013, 06:14 AM   #372
I dont think its possible to alter the wb, at least not with its prescribed parts.
Old 09-07-2013, 03:32 PM   #373
Hi
Im having a little trouble with my xv01. I use mine on tarmac and gravel and a few jumps.
Basically the steering is all over the place.
Every bump and the steering alignment is either to the right or left by alot.
I took the car apart, rebuild using shims to eliminate some of the slop and still no gd.
Checked turnbuckles are straight and same lengths
Using:
Savox servo 1251mg
Kit servo saver
Front buggy CVA's with tb01 springs (longer than TRF's and just enough that the steering doesn't catch on chassis)
alex_evo is offline   Reply With Quote
Old 09-07-2013, 04:11 PM   #374
Raman's Avatar
There is a spacer in front of the rear suspension holder.. (step 19 NN23 in manual) if you built the car as per manual, you are already running it 2mm shorter wheelbase.
In addition, there is a 4mm spacer on the rear upright that can be moved in front and back of upright. (Step 22 NN19) If you built as per manual, you can shorten wheelbase by switching the spacer to the front of upright.
I think it will be close but not perfect.
Old 09-07-2013, 04:13 PM   #375
Raman's Avatar
Originally Posted by alex_evo View Post
Hi
Using:
Savox servo 1251mg
Kit servo saver
The kit servo saver is the plastic one right? No metal parts? If that is the case, that is most likely your culprit
::: Tamiya XV-01 PRO Rally 1/10 Review!!! ::: iluvm4 Electric Off-Road 17 05-04-2017 09:37 AM
Electronics for Tamiya xv 01 highbeam Radio and Electronics 10 12-23-2012 07:56 PM
