Like Tree19Likes
Old 04-08-2013, 08:57 AM   #241
macavant's Avatar
Trader Rating: 64 (100%+)
There is also the Double Cardan Joint shaft option - but costs a lot more. I have the DCJs on my TRF417 and they are solid units. No chatter even at full lock, on power.
I'm thinking of going to DCJs when the front CVDs of my XV-01 goes south.
Here are the parts I'm looking into for the conversion:
DCJ kit: TAM42216
42mm shafts: TAM42239
likes the oldskool RC action...
F201☆F104WGP☆M01.M05.YR4MSe.TA05.XV-01Pro.ABC_Genetic(Exotek)☆microRS4-Motek☆TA02SW☆WR02.CC-01.G6-01.SandScorcher☆TRF201☆TRF417X.TRF101.TRF101W
macavant is offline   Reply With Quote
Old 04-08-2013, 10:36 AM   #242
Would the XV-01 pro cvd setup be the same for front and rear? The stock kit haa different axle setups front and rear? So will the cvds Forgetful Duck suggested work for the rear as well? I'll look into the DCJ kit but probably go the budget way with the TRF417 cvds. Thanks
Sapes is offline   Reply With Quote
Old 04-08-2013, 10:46 AM   #243
macavant's Avatar
The rears are shorter - 39mm swing shafts. Here are the part #s according to my manual:
39mm swing shaft: TAM53505 [BD4]
wheel axle (long): TAM19804648 [wheel axle long, BD5]
edit: look for this # instead: Tamiya 9804648
TamiyaUSA
Old 04-08-2013, 11:15 AM   #244
that makes sense but again I can't find the large #part for the long axles. Same problem I was having with the other part. I can find the shorter drive shafts.
Old 04-08-2013, 11:55 AM   #245
macavant's Avatar
Checked my Tamiya cross parts list and it shows this for rear axles:
TAM51513
Unfortunately I don't see a cross reference for the XV-01 Pro rear axles; just the Tamiya 9804648. If you want - PM me your email adress and I can share with you the cross reference parts list.
Old 04-09-2013, 08:38 AM   #246
stormridersp's Avatar
Originally Posted by clittle View Post
I'm about 90% through my build of the XV-01PRO TC... and I have noticed that for offroad (I know it's a TC kit, but hey ), the Reversible Suspension doesn't give you a lot of ride-height in the front... I'm going to put the longer of suspension holders but even then, it's not going to give me much... The arms hit the chassis at just a little under horizontal.
How was the older Pro kit, or the normal kit for that matter, in terms of ride-height on the front?
I know in this kit, it's the suspension arms hitting that are the limiting factor.
I'm not looking for stupid height, but just something a little more.. especially given that the weight is almost all in the front.
(ed) I've just looked at the manual for the original Pro kit. They've raised the suspension block holders just a little (1mm in the front and 2mm in the rear), this in theory should give me more leverage allowing more ride height. I guess I'll just give it a go and see....
Cīmon man, post a few pictures of the machine please!!!
stormridersp is offline   Reply With Quote
Old 04-09-2013, 07:37 PM   #247
clittle's Avatar
Sorry mate, life got in the way... Give me a couple of days and they'll be up.
Latest is a Tamiya TB04 Pro..... Love it!!!
Aussie in Japan!
clittle is offline   Reply With Quote
Old 04-15-2013, 01:09 PM   #248
SerpentCT4S's Avatar
Trader Rating: 94 (96%+)
Send a message via AIM to SerpentCT4S
Finally have some time and nice weather to spray my body!
I will update with pics when its done!
SerpentCT4S is offline   Reply With Quote
Old 04-18-2013, 02:28 PM   #249
Raman's Avatar
Trader Rating: 56 (100%+)
Received and installed my Tamiya Blue / Carbon hop ups courtesy of Bonzai Hobby
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 04-18-2013, 11:11 PM   #250
metalnut's Avatar
Trader Rating: 36 (100%+)
How do you like the aluminum steering rack? I don't notice any major slop in mine, is the upgrade worth it?
Team Nervous | Team Scruffy | Team Orange
"If you ain't first, you're last!"
- Ricky Bobby
metalnut is offline   Reply With Quote
Old 04-19-2013, 11:24 AM   #251
Raman's Avatar
Honestly.. it looks nice but thats it.. I agree with you the original did not have much slop. Banzai's prices are cheap so thats why I went for it.
Of the 3 hop ups i installed, the only one that offers a true benefit would be the rear shock tower which has 3 additional shock positions. The front shock tower doesn't have any new positions.. because of the design of gear box, its not possible to have additional mount points in wards.
Old 04-21-2013, 06:18 PM   #252
macavant's Avatar
Finished the LED lights and the cockpit set on the XV. Had to settle for the touring car set - as the actual rally cockpit sets are getting harder to find.
Part# for the set is: TAM54147, comes with 2 helmets, decals, and mounting hardware.
Old 04-21-2013, 08:53 PM   #253
Originally Posted by rtypec View Post
Here's some eyecandy
Your wheelnuts are not threading into the nylon, and will most likely fall off if you try to run it like that.
Eivind E is offline   Reply With Quote
Old 04-21-2013, 11:11 PM   #254
metalnut's Avatar
Freakin' Eagle Eyes over here... seriously, nice catch man! And you're right, that's a recipe for a bad time.
- Ricky Bobby
Old 04-22-2013, 01:58 AM   #255
Sith Lord's Avatar
Trader Rating: 21 (100%+)
He might have packed the axles full of spacers so the tyres filled out the guards perfectly for the photoshoot
Tamiya XV-01 Rally :: Tamiya FAV 2011 :: Proline Pro2 SCB
Sith Lord is offline   Reply With Quote
::: Tamiya XV-01 PRO Rally 1/10 Review!!! ::: iluvm4 Electric Off-Road 17 05-04-2017 10:37 AM
Tamiya Xv-01 new Rally Kit releases in July rcmart rcMart.com Mega Online R/C Marketplace 17 01-04-2013 02:54 PM
Electronics for Tamiya xv 01 highbeam Radio and Electronics 10 12-23-2012 08:56 PM
