Like Tree4Likes
Old 02-19-2013, 09:02 AM   #151
Brushless Or Nothing
dark_luna is offline   Reply With Quote
Old 02-21-2013, 06:52 AM   #152
+ YouTube Video
http://www.youtube.com/watch?v=Qlcs_Di7cik
Old 02-21-2013, 10:27 AM   #153
Raman's Avatar
Trader Rating: 52 (100%+)
Just received my speedmind tyres from RCMart.. I accidentally ordered the RT27 road not the RT28 rally..
This is what happens when you order using a mobile phone lol. I placed an order for the correct ones today.
Anyone need some speedmind Tarmac tyres? Lol
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is online now   Reply With Quote
Old 02-21-2013, 01:20 PM   #154
Hehe the road fighter tyres are not good for anything but the rally block are great!
Old 02-23-2013, 07:48 AM   #155
metalnut's Avatar
Trader Rating: 36 (100%+)
My kit is 95% assembled! It went together pretty easily, the only issues were ones I created Now I need to work on the body, I think that'll take some time.
Are there any other body posts out there that fit the XV-01, specifically shorter ones for the back? I know I can cut the stock ones, but I was just curious. The back will be WAY too long, and it also hits the window of my chosen body. Not great, but what can you do.
metalnut is offline   Reply With Quote
Old 02-23-2013, 12:48 PM   #156
I guess the body posts on this one is quite unique, you can mount them on the other side of the shock tower if that gives them a better position. But don't be afraid to cut them though, I do that on basically all my models
diHib is offline   Reply With Quote
Old 02-28-2013, 06:00 AM   #157
stormridersp's Avatar
Ok, the XV-01TC's manual is taking some time, but the parts listing is out!
http://www.tamiyausa.com/product/rcp...s&kit_id=58558
And as mv75 noted at URC forums, the touring kit uses a longer piston shaft up front and that solves the short ball joint mistery and also the bottoming out problem!
http://www.tamiyausa.com/product/ite...uct-id=9804706
stormridersp is offline   Reply With Quote
Old 03-01-2013, 09:29 AM   #158
Originally Posted by dark_luna View Post
Thanks Phil
2.
Front sway bar needs to be shortened and both front and rear needed some adjustment of the angle. #51111 4mm rod ends on suspension arms and the 5mm need to be shortened 2mm. I still waiting for the #53827 Stabilizer rod stoppers I ordered.
Hi dark_luna, I have some questions for you regarding the sway bars. Yesterday mine finally arrived from HK and I tried my best to match your installation, viewing your photos.
Iīve sanded down about 2mm altogether from both ball joints, the 4mm and 5mm and screwed them in the maximum I could. On the rear, Iīve also installed that spacer to raise the rear turnbuckle arm, just like you did and fixed them sway bars in place using those rod stoppers, and adjusted the best I could the arms angle, so they donīt touch either the dogbones nor them turnbuckles.
What Iīve noticed right after is that the rear arms now dont move as freely and smoothly as the front. Are your sways working perfectly and smoothly?
Old 03-03-2013, 12:26 AM   #159
metalnut's Avatar
Edit: to answer my own (stupid) question... running the XV on 3S Lipos is a dumb move on my behalf. It, like other 10th scale TC cars, run much better on 2S. So, buy 2S
Old 03-03-2013, 12:22 PM   #160
rtypec's Avatar
Default Subaru Impreza WRX STI - Team Arai
Here's some eyecandy
rtypec is offline   Reply With Quote
Old 03-03-2013, 12:31 PM   #161
madjack's Avatar
Trader Rating: 19 (100%+)
Send a message via Yahoo to madjack
That's too pretty to drive
madjack is offline   Reply With Quote
Old 03-04-2013, 06:00 AM   #162
So, the XV-01TC is already out and stocked anywhere, does anyone has it in build or anything to show yet? I'm bitting my fingers with curiosity!
I'm also killing to see its manual and compare with my Rally Pro version!
Old 03-04-2013, 06:26 AM   #163
Nice. Well on my, rear is working very well no binding, but front don't move as freely and smooth. I think it's the 5mm ball joints that's a little sluggish.
Old 03-04-2013, 06:27 AM   #164
Wow very good looking, nice job!
Old 03-07-2013, 12:20 PM   #165
Good news, XV-01TC manualīs PUBLISHED @ Tamiyausa.com!!!!
http://www.tamiyausa.com/product/ite...oduct-id=58558
Hope you guys enjoy!
::: Tamiya XV-01 PRO Rally 1/10 Review!!! ::: iluvm4 Electric Off-Road 17 05-04-2017 09:37 AM
Electronics for Tamiya xv 01 highbeam Radio and Electronics 10 12-23-2012 07:56 PM
