Old 04-13-2005, 12:51 PM   #1
Default Novak GT 7 wiring mod help
Can anyone tell me the wiring mod for the gt7? I have just got one and the wires are about 2 inches long. How many diodes are fitted?
Bryan D is offline   Reply With Quote
Old 04-13-2005, 01:46 PM   #2
Charlie's Avatar
I think you are talking about the Pre-Installed Schottky Diode on the wires.
It's a schottky diode and must be used for the Long Life of the GT7. You can take it off the wires and install on the motor directly if you like as well.
The case label has the power wire sequence on it.
Novak Electronics Tech Support
Charlie is offline   Reply With Quote
Old 04-14-2005, 02:11 AM   #3
Thanks Charlie, I thought there might have been more than one fitted but I was not sure.
Old 04-14-2005, 06:43 AM   #4
Joel Lagace's Avatar
The pre installed one is huge! Im assuming that replacing it with a tube shapped unit soldered to the motor is same? I got one used and it had been in a shaft drive car so i had to install new power leads to go into my buggy. I just did not want that large diode/board in my new wires so i used the motor mounted diode instead
I really wish ESC tech would get these along with caps installed with in the ESC case........... I know time will improve tech...
"Without Rules its just Backyard Bashing!"
Joel Lagace is offline   Reply With Quote
mamba w/ novak motor wiring party_wagon Electric Off-Road 1 08-16-2008 11:07 AM
7.2 v KO servo wiring & PT wiring issues bshookup Radio and Electronics 2 06-12-2008 12:23 PM
Wiring up a Novak GTB...... GundamWZero Electric On-Road 13 02-26-2007 10:31 PM
Wiring up an ESC Iceracer Electric Off-Road 3 07-19-2006 01:21 PM
wiring rx-7 Singapore R/C Racers 9 10-02-2002 01:21 AM
SEO by vBSEO 3.5.0
