Old 12-24-2012, 04:03 PM   #1
Roelof's Avatar
Send a message via ICQ to Roelof
Default Current drain out of the ESC sensor connector?
I am busy with a tool for a technical inspection (can not tell yet what, it must be a supprise) but it contains some electronics. Because I need to take a signal from one sensor it would save me in building (and the guys using it in action) if I could take the 5 volt voltage directly from the sensor cable.
The total current draw will be nothing more than 60 mA (3 LED's and some very low power chips), so not much.
But I can imagine the power this cable is somehow limited due a chance of a broken or damaged wire and so a shortcut with the already low power sensors.....
I do not own a sensored brushless setup so I can not try but I think it will be used mainly on a SP Citrix ESC.
Anyone know this?
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
SEO by vBSEO 3.5.0
