Old 04-11-2005, 03:10 AM   #1
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
Default Delta Peak for NiMH2 on Millenium Pro
Does anyone know what the Delta Peak is for the Millenium Pro?? I need to know because you aren't supposed to go SOOOO high for the IB3600s and I just want to be sure about it.
Thanks guys.
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Old 04-11-2005, 03:56 PM   #2
Charlie's Avatar
Well, the whole point of the NiMH2 mode in your Millennium Pro is that it doesn't use Voltage Threshold or "the standard" type of peak. The idea is the NIMH2 mode watches differently and protects the battery better.
If you want to VT charge, simply use the NiCD LInear Mode and adjust to your desired setting.
Novak Electronics Tech Support
Charlie is offline   Reply With Quote
Delta Peak with pulsar Pop. Electric On-Road 2 02-07-2007 09:52 AM
What Delta Peak should i set?? TRFTIM Electric On-Road 1 01-02-2007 11:18 AM
Delta Peak ? hckeyplayer74 Electric On-Road 7 01-01-2007 12:52 PM
Delta Peak josh69162 Electric On-Road 3 10-02-2005 11:25 AM
SEO by vBSEO 3.5.0
