Kyosho Touring Car
#1951
They are 17, 18, 19lb springs. Yellow is 18lbs. I don't remember if blue is 17 or 19. I think blue is 19lbs but no promises.
I run Corally black springs.
#1953
#1954
if you look in the manual it normally may say which type of spring comes in the kit, with a (*1) or something like that next to it.
i pulled my shin edition out the other day and couldn't believe how worn some bits were form running it with a 8.5T, so i spent the rest of the day rebuilding it and decided ill give it a go running 540pro again.
the only problem was i needed to make up a side bracket so i could put my lipos out to fit, plus this allows for easier placement for the lead when i get round to doing a 50/50 balance, as im 100gm under weight at the moment.
Haven't quite finished it yet, rear tyre comes a bit close so need to cut some away, and when finished i will paint the alloy to the same red as the chassis to match, as have found an brand of paint that has very similar colors to chassis brands, as a friend used the same paints for his xray 009 and it came up almost prefect match to the anodizing.
#1958
spool and ball diff tube
hello
in use to run with a TF5 Stallion Shin and but i have to change every times (4/5 packs) my spool and rear diff ball tube because they are really use!!!!
do you have any reference or a solution to change this parts by others???
thank's a lot...
Redbull from france...
thank's a lot...
#1960
hello
thank's a lot...
thank's a lot...
I think it cause I run the belts super loose. I run 10.5 and 17.5. It has been hands down the best car for me. I have thought about going to the shin edition or maybe the shaft car.
#1961
thanks
my problem is not the diff balls but the spool and rear diff tube....
but i use a 6.5T/5 cells NiMh maybe it's normal!!!
i saw on photos other spools on the race cars but i don't know what is it..
if anyone know....
Redbull
if anyone know....
Redbull
#1963
Is there a resource that says what the different pieces in the suspension blocks do? TIA!
#1965
