Kyosho Touring Car
#1756
rc maket does stock some stallion shin parts.
#1757
Ok guys I am need of some help.
My stallion has been on rails for a good month or so and THEN the big one happen(super bad wreck with lap traffic). It bent the motor bulkhead and 2 hinge pins and snapped the chassis off behind the front bulkheads( I did almost cry). I bought all new pieces and put it back together. Thanks Kyosho USA!!!!!!
Well now the car want to pull to the right when I get in the throttle. I did used my scales and balanced the car. Everything looks superb. New Solid in the front and rebuilt the diff.
Any suggestion??????? Can it be weight transfer?? Man I am confused.
Thanks for the help guys.
Hey does anyone know if a lipo will fit in the Shin?????
#1758
gees you must of had a very fast crash to cause that much damage, ive crashed my car at full throttle with a 8.5t BL into a metal fence and all it did was dent the body
just a thought from me racing today, one of your front bearings could be stuffed so it may cause it to pull to one side as you would get more drive in the left tyres
or it could be basically the front right tyre is out of alignment, as you wouldn't normally get torque steer in a belt car its very unusually, generally in the shaft cars people have problems, but there is always a first time
#1759
Have you checked the top deck ? I broke mine in a crash and you could barely have noticed it. It breaks at the rear... The car did exactly that, pull to the right on power...
I wouldn't think lipos will fit the car no.
#1760
i think TRF415boy could have something there about the kingpins.
just one question, why did you go and get the spare parts that you had broken when it would have been smarter to probably get a second hand car or even a new one for a slightly more cost then using the straight parts as spares.
#1761
I did check the bulkheads but not the top deck. I will look at it and see if the problem is there.
The car just happen to hit a large piece of metal angle iron at full speed upside down and in the air. When it hit it sounded sick.
I will also check all the bearings also.
#1762
#1763
gearing
curious what gearing you guys are running , i have the stallion belt car with a vortex 10.5 , spur is a 106 with a 39 pinion seems a little slow any suggestions ??
#1765
post
i think it's already out i saw something on ebay shin kit ,or maybe rc mart
#1766
parts
i know it's already been posted somewhere but im looking for the best place to get parts for the tf-5 stallion ???? besides speedtechrc , no phone number to get ahold of them
#1767
http://www.redrc.net/2007/05/hirosak...lion-up-close/
#1768
#1770
