Kyosho Touring Car >
Kyosho Touring Car
Kyosho Touring Car
Old 07-10-2007, 09:43 AM
  #1516
Trader Rating: 40 (100%+)
I will try to make it out on thursday. Do you know what time he will be there??
King of B Main is offline
Old 07-10-2007, 09:50 AM
  #1517
GCracker's Avatar
Hi Mike, Figure 6pm is good, hes usually there from 5:30 on but just to be safe 6.
GCracker is offline
Old 07-10-2007, 11:19 AM
  #1518
Location: Bending Corners R/C Raceway(s) 2190 North Canal Street Orange, CA 92865
Official Trophy Race Name
"The Summer Slam"
presented by
Bending Corners Raceway(s)
Flyers are being completed and will be distributed this week are you on the mailing list?
see track photos at http://bcraceways.smugmug.com
Mark [B]your calendar for Saturday, August 18th for "The Summer Slam"
Hey Kyosho, Bending Corners Raceway is also looking for prizes for this event. So if you are interested please email me as you know, I will be calling you.
Raffell
TireShredder is offline
Old 07-11-2007, 07:14 AM
  #1519
Hi I'm just wondering what the effect is of lowering the rear diff and/or
the front spool in the Stallion?
If you could help please Mark.
ODEN is offline
Old 07-11-2007, 07:44 AM
  #1520
Trader Rating: 27 (100%+)
Oden -
My notes around this are;
-high, will make the car run flat but more responsive.
-low, will increase onpower steering
Generally, I run low front (spool) and high rear (diff).
Two things to watch for;
1- as bite increases the rear might feel it wants to drive over the front. TIme to start lowering the rear diff
2- if the car feel too twitchy off-center; raise the front.
MDawson is offline
Old 07-12-2007, 01:44 PM
  #1521
GMartinez's Avatar
Trader Rating: 91 (100%+)
Just a quick FYI noticed that on the japan site the new chasis,upper deck,shock towers & a few more items are showing up available in July so looks like we shall see them in the U.S. soon
GMartinez is offline
Old 07-12-2007, 07:49 PM
  #1522
Patriiick's Avatar
could we attempt a conversion from a regular chassis to a Shin edition ?
Granted that would be costly, just wanted to know if with just the new center bulkhead and the chassis it would be enough to convert?
Thx
Patrick
Patriiick is offline
Old 07-12-2007, 08:09 PM
  #1523
Thx
Patrick
Hi Patrick.
The key parts needed would include;
-Revised steering assembly
-Shin upper and lower graphite
-Shin right bulkhead
-Shin graphite rear X brace
There are also thicker shower towers and wider suspension block mount. The key parts listed above would get you pretty close.
The setups are pretty adaptable from the Stallion to the Shin Edition.
Good luck!
MDawson is offline
Old 07-13-2007, 02:42 PM
  #1524
ANDY TF5's Avatar
hi guys does any one know where there are some set up sheets for the stallion car on the net
ANDY TF5 is offline
Old 07-13-2007, 03:45 PM
  #1525
Aside from other owners here on this thread, you can also look at www.kyosho.com .
Let us know the track type and surface and we can steer you the right way.
MDawson is offline
Old 07-14-2007, 10:54 AM
  #1526
ANDY TF5's Avatar
thanks MDawson im running indoor on carpet in the uk with the basic set up which is good but on about going outside on tarmac running 19 turn what shells do you run i run the andy moore dodge stratus which seems to make the car feel safe
thanks for your help
ANDY TF5 is offline
Old 07-14-2007, 07:42 PM
  #1527
Hi Andy
I would start with the Protoform Mazda Speed6 or Mazda6. For a good outdoor setup, try the setup I post some pages back.
Good luck
MDawson is offline
Old 07-19-2007, 10:57 PM
  #1528
Scrad's Avatar
Trader Rating: 16 (100%+)
Is there a 5 cell chassis available? I remember seeing some pics of one of the Japanese drivers cars with the standard stallion bulks, but the cells were moved more in toward the centerline with 5 cells.
Scrad is offline
Old 07-20-2007, 05:29 AM
  #1529
idawina's Avatar
Hey guys i was wondering if someone could help me to find part number for the plastic outdrives used in the front spool for the stallion. They are listed as part 141 in the manual but there is no reference to part 141 in the spare parts listings!! please help!
idawina is offline
Old 07-21-2007, 02:46 PM
  #1530
blown sv's Avatar
just a question for the pro's
i run on ashaplt ,medium grip using foams 40 shore, 3.5BL , blue front springs ,yellow rear, everything else is as per kit setting
having trouble with the rear snapping on weight transfer(say through a quick left right) ,has heaps of steering
any help
thanks
chad
blown sv is offline
