Old 04-07-2005, 07:36 PM   #1
rough512's Avatar
Default How much reverse current can NiMH tolerate?
or How do you care for stick packs?
The packs in question are for TCS so I can't convert them to side by sides.
I remember reading an old Tekin Charger manual. It says to attach a 30 ohm resistor on the Nicad stick pack when storing.
So, if I discharge the pack down to 5 volts and at 5 volts, one cell (let's call it cell#1) is already at 0 volts. Then I attach a 100 ohm resistor across the entire pack and leave it overnight. This would put 50mA reverse charge current through cell#1.
Would this ruin that cell?
rough512 is offline   Reply With Quote
Old 04-07-2005, 10:43 PM   #2
Send a message via AIM to micros_rock
Unfortunately, stick packs make it hard to equalize or safely discharge the cells to low voltages. If you really feel like it, take apart the stick pack, equalize the cells as a side x side pack, then remake it into a stick pack for the race. But I'm not sure all the trouble would be worth it.
micros_rock is offline   Reply With Quote
Old 04-07-2005, 10:48 PM   #3
rough512's Avatar
thanks for the reply...
I don't think the pack would still be TCS legal even if it's rebuilt back into a stick pack. If it would still be tcs legal, I would install small wires between each cell and equalize the pack using those wires. . but it's NOT legal.
Old 04-08-2005, 12:35 AM   #4
Cole Trickle's Avatar
That dont leave many choises....
I would simply get a discharger with auto cut off. Like the Integy Reactors. Reasonably priced, and if you open it, you can adjust the cut off, if needed (can void warranty, though). Avaible in 20 and 30 amps versions, maybe also 10 or 15, cant remember...
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
LRP F1 Super Reverse, Cant Get Forward/Brake/Reverse ? SDNitroGuy Radio and Electronics 0 06-09-2008 09:34 PM
WTB: Matched 3700 Nimh up to 4700 Nimh smarking1212 R/C Items: Wanted to Buy 5 04-16-2008 09:33 AM
spektrum z590 servo,4200 nimh,3800 nimh and duratrax piranha peak chager nikkon R/C Items: For Sale/Trade 9 02-11-2008 05:19 AM
Lithium Polymer - Are Any of the Current NIMH Matchers Experimenting with Lipoly?? 403forbidden Electric On-Road 28 10-03-2004 10:13 PM
Charging NiMH Cells - not at full current? lush Australian Racing 12 08-27-2003 11:06 PM
SEO by vBSEO 3.5.0
