Tamiya TA05 Touring Sedan
#7951
totaly incorrect, although they are very VERY similar, Tamiya supply .4module pitch gears with the TA05R, which is obviosly METRIC. 64dp is an imperial measurement, they are not they same, not to be confused as the same either. You run either one or the other, never a mix.
#7952
I am having problems with the 49.7mm Titanium Coated Suspension shaft, it looks like that it does not take a small impact at all, however, the stock suspension shaft seems to be stronger. Do anyone have this problem?
#7953
Had the same problems with the Titanium coated pins aswell. Not bent a steel one yet
#7954
sorry, but i was referring to .04 as being called 64 metric, just like you would see in this tower description for .06 http://www2.towerhobbies.com/cgi-bin...?&I=LXEX46&P=7
#7955
#7956
I would not recommand use 64P (unless it is necessary) pinion and use the Tamiya 0.4 Pitch spur....it damaged my F103GT 0.4 pitch spur on the recent TCS race within 30 minutes of run time.
On my TA05R...I replaced the Tamiya 0.4 pitch spur and use 64P 108T (the biggest that you can use on TA05R)....then use all the 64P pinion that you can easily find in USA and LHS....problem solved.
On the recent outdoor rubber stock racing....I was using 28t/108T Trinity CO27 motor....had faster race time (5 minutes) then brushless modified car...
Yes...the TA05R suspension drive pins are HORRIBLE...mine bent UPWARD (ended up anti-dive on 1 side...WEIRD)....I ended up cutting some NTC3 shaft, some cheap steel material....wacked several times, not a single problem (Serpent 3mm shaft works too....even stronger).
#7960
Solara: you are right, it is a 105 tooth spur.
I just bought these:
http://www2.towerhobbies.com/cgi-bin...?&I=LXTG10&P=7
#7961
http://www2.towerhobbies.com/cgi-bin...2&I=LXEZ13&P=K
#7962
One time I got rear anti-squat
#7963
Is this the 108t 64p gear you used? If not, anyone know if the Robinson type ones mate up (hole position, center diameter) to the Tamiya center shaft and pulley?
Speedtechrc.com has a line of spurs and pinions made by Xenon. Those are the ones I use
#7964
The Robinson spurs fit perfectly on the TA05. They are by far the best spurs that I've ever used. I race outdoors so I like to use 48 pitch, plus that's what I use on my off road cars and it's nice to be able to use the pinions and spurs that I already have and will have on any of my cars.
Jim
Jim
#7965
Jim
Jim
Edit: This is a picture of my car.
