Tamiya TA05 Touring Sedan
#1307
Cool..
Thank's Tony I'll be down there Tuesday.
I'd like to take a look at a TA05 up close.
Scott.
Scott.
#1308
Originally Posted by racer
for the people who ran their TA05's on carpet. can you give some feedback to the car?
Thanks in advance!
Thanks in advance!
#1309
Thanks in advance!
Thanks in advance!
People who beat me last winter were behind me, with Xrays and TC4's, the guy who beat me, fastest lap was 0.2s faster and his car is about 110 grammes lighter than mine, so, you could say the car is competitive.....
#1310
I had no intentions of running this car on foam tires on carpet-but after reading all this stuff-It might be worth a try. Though the car is so flexible out of the box. But-who cares-its a $140 car!!! I am trying to commision a series of CF chassis, top decks and stand-offs for the car-but it may be near impossible at this time. But could you imagine the chassis in 3mm Quasi-isotropic with a 2.5mm top deck and aluminum standoffs?
Does anyone have a .dxf file of the chassis?
Thanks,
Ray
Thanks,
Ray
#1312
DIY CF chassis? I would say: wait Square...
#1313
Nah-I wold never make a do it yourself chassis. It would be proffesionally done by a machine shop or not done at all. Besides-Squares is bound to be 2mm or 2.5 but swiss cheesed for flex and lightness-which leaves you with a lighter-but no more stiff chassis than the oriinal-right?
#1314
Does anybody know how much weight would be saved when I use:
-Lightweight suspension
-Alu turnbuckles and connector balls
-titanium screw set
Anyone have an idea?
Alwin.
-titanium screw set
Alwin.
#1315
Originally Posted by cheehtae
Raced my Ta05 again last night, sad to say I did not like the way it perform eventhough I've added some upgrades ( swingshaft, TRF shocks, CF shock mounts) it just was'nt smooth enough.
QUESTION: how loose should the diff be? I did loosen it up a bit, REASON: whenever I would let off it will just try stop to soon, . . . [question about carbide diff balls]
#1316
-titanium screw set
Alwin.
-titanium screw set
Alwin.
#1317
Originally Posted by MobileIT
I do not know what you mean by "smooth"?
That does not sound like a diff problem.
Kidding aside: compared to my Xray its not that smooth, on my Xray I could barely hear the diffs, don't think I Have a diff problem I just rebuilt it, well let's see------- With the Xray if I let off it just rolls and then stop slowly or smoothly BUT with the TA05 it just stop abruptly. I hope you guys know what I'm talking about---- I did interchange the speedo , and its still the same thing. anyways any input?
#1318
That could be a number of different things, firstly, is the transmission free in as much as will it roll on a gentle slope, if not, then first reset belt tensions back to factory settings, if they are, then check bearings.
If it does roll free, then it got to be something you are putting in the car or using, like a motor with very strong magnets, or inadvertantly set drag brakes.
#1319
Check out the TA05 roller I have up in the For Sale section...sweet.
#1320
any one knows what the part no. for the 5mm or 6mm. alloy hex hub that will fit the TA05?
