Tamiya TA05 Touring Sedan
I recently picked up a used TA05R and was wondering wich ESCs you are using? I have 4 and couldnt find one to fit in the small area behind motor. The smallest one I have is an LRP bullet reverse that looked like it would work, but still @5mm too large. Thanks for any input Im not sure if Im gonna run brushed or brushless yet.
This is one bad part about tub TA05R, I have to take off some plastic here and there to fit a Speed Passion GT speedo....Novak GTB (HUGH for my standard) somehow fit perfectly without grinding...the no need modification model of BL speedo are Tekin, KO, Orion, Novak...
Thanks!
Ive had no probs with mine like that.
I use an LRP Sphere Competition in my TA05-R -- fits perfectly.
my ESC is small enough to go in front of the motor I'll probably be changing it in the mid future though, as it's still the one that came stock with my E10
getting stuff in the gears
Hi there. I seem to have a bit of an issue with stuff/bits of grit(glass??) getting caught betweeen the pinion & spur
Its happened 3x in the last 2 weeks, ruining the pinions
Can I cover up the hole in the bottom of the chassis to possibly stop stuff getting sucked into the gears??
Yes you can, although if you are planning on running it on the same surfaces again, the grit or stones will just get caught and grind up the gears even more because of their 'escape' hole blocked. Best bet is just to not run it the same surfaces.
try using a bit of sticky tape over the bottom hole and hope the grit will stick to it rather than get up in the gears. Crashes might dislodge it though and throw it up in the mesh anyway, but I don't see what else you can do short of not running on that track as suggested above.
I have another question for Ta05 owners. Im newer to the hobby and my Ta05. Iam enjoying hopping up the car w Tamiya parts. My local hobby shop has a Tamiya carbon chassis for Ta05. The question- Is that a good upgrade for a car that will race only asphalt & rubber tires? Seems asphalt racers like some flex in cars? Fifty bucks spent somewhere else may help more. Thanks for any input.
