Tamiya TA05 Touring Sedan
To all the Perth guys, where do you buy your Tamiya parts from? Online or hobby shops?
unfortunately I can't see your pic, can you throw a link up?
R/C Tech Elite Member
its a case of emergencies only for me when it comes to LHS purchases
i tend to use these, probably in order of preference..
- www.rcmart.com
- www.rc-mushroom.com
- shopping.rcmodel.hk
- www.rcmarket.com.hk
-Mark
Very rarely do i buy parts locally, not because i dont want to but it helps when parts are in stock and they are not more than twice that from overseas..
- www.rcmart.com
-Mark
- www.rcmart.com
-Mark
I use (in order)
www.harrisrc.com
www.liquidrc.com
www.vellrip.com
www.precisionrc.com
www.amainmodels.com
www.stellamodels.net
shopping.rcmodel.hk (out of date site, half the items he says are in stock aren't)
www.rcmarket.com.hk (can be a bit rude in his emails)
www.rc-mushroom.com (crazy high postage)
www.rcmart.com (terrible processing time)
www.hobbycity.com (even worse than rcmart processing times, didn't think that was possible)
i've been looking for the tamiya universal joints / axle combo but can't find it anywhere
all I can find are the yeah racing etc etc ones. Same as the TRF shockies.
The bog stock IFS runs the first type of reversable arms with those damn 950 wheel bearings (the IFS-R runs the 416 set up with 1050's)
You need:
51094 (Wheel Axle)
53500 (Cross Joints)
53836 (Swing Shaft 48mm)
for the front.
51094 (Wheel Axle)
You can use the standard 48mm swingshaft here or the lightweight Blue one, do not use the blue up front though!
You need:
51094 (Wheel Axle)
for the front.
51094 (Wheel Axle)
i dont think there's a complete set for the universals
(could be wrong, havent looked for a while)
you just need these..
53871 - Rear lighweight swing shaft, 48mm, blue annodised
53836 - front steel swing shafts, 48mm
53500 - cross joints, pins, grub screws
53499 - wheel axles for universals ** need two packs
-Mark
-Mark
-Mark
-Mark
I think I have found the uni set? This would be ok front and rear on the IFS?
http://www.vellrip.com/store/product...asp?p=944&c=41
Could someone who has upgraded to the carbon damper stays be kind enough to help compare the holes for front damper mount position 1,2,3,4 and rear 1,2,3,4,5 with those on the stock plastic damper stays?
thanks!
thanks!
Integy set up station.
http://www.integy.com/cgi-bin/webc.c...=1886&p_catid=
At Tower it's $65.
You can measure links etc.., but that's never 100%.
I have some digital calipers that have a resolution of .001 MM.
Got my links to exactly the same length and put them on the car.
Yesterday I put both cars on the setup station and could see 1 and .5 degree differences. Is it huge? no. But when anyone is trying to improve a skill, making sure the set up the same is important.
At Tower it's $65.
the difference being on the carbon towers you have the additional hole 4
-Mark
You need:
51094 (Wheel Axle)
for the front.
51094 (Wheel Axle)
You need:
51094 (Wheel Axle)
for the front.
51094 (Wheel Axle)
What parts do you need to switch the front steering blocks from the ones that use the 950 bearings to the 416 blocks that use the 1050 bearings ?? (I have a TA05-R that has the LW suspension and the steering blocks that use the 950 bearings and would like to switch them to the 416 ones).
Thx.
54083 - RC Short Reversible Suspension Set
http://www.tamiyausa.com/product/ite...oduct-id=54083
I'm guessing you'll also need shorter swing shafts (eg. 42mm as opposed to 46/48mm)
