Tamiya TA05 Touring Sedan >
Like Tree68Likes
Old 06-21-2008, 11:05 PM
  #9376
7.5 would be 21T with 70T spur, or if you have the 05R, 31T with 105T spur will give you 7.62, and 32T will give you 7.38.
stocker is offline
Old 06-22-2008, 04:53 AM
  #9377
DJ
hi thanks your suggestion been noted
another question , is it worth it to convert my TA-05 to TA-05 IFS?
or upgrade my TA-05 as it is? (bling bling factors)
DJ is offline
Old 06-22-2008, 10:10 AM
  #9378
94eg!'s Avatar
Trader Rating: 17 (100%+)
Hmmm, the TA-05R is "discontinued" ?!
http://www.tamiyausa.com/product/ite...oduct-id=49418
That just means they are out of stock...
94eg! is offline
Old 06-22-2008, 10:47 AM
  #9379
Originally Posted by DJ
Hi guys, newbie here
What combo of SPUR and PINION GEAR can you suggest in brush 23t motor for my TA05? Im using NIMH bat.
thanks in advance to all
Hi Dj,
On a small, tight carpet track we used to mount 32-34t pinion depending on the track. On a large carpet rack 33-35t pinion will be a good choice.
On asphalt we used to mount 36-40t pinion depending on the size of the track. Mostly I prefer 37-38t.
We use 105t spur.
These ratios are only good for the Tamiya TZ/RZ.
ciao
bviktor is offline
Old 06-22-2008, 11:18 AM
  #9380
academygaz's Avatar
Quick Q, the 05R comes with a ''53857 04 GP Spur Gear 105T'', is that another name for 64dp?
academygaz is offline
Old 06-22-2008, 12:35 PM
  #9381
Hi,
Not exactly. Tamiya has own gear moduls, but the modul 04 is very similar to 64dp. So you can combine the Tamiya 04 modul gears with 64dp gears. I use titanium racing 64dp pinions with the 105t spur.
ciao
bviktor is offline
Old 06-22-2008, 02:24 PM
  #9382
94eg!'s Avatar
You would do better to just install a 64-pitch spur (or order some Tamiya 0.4-module pinions)...
This pic shows you module vs. pitch. They are not interchangeable (metric vs imperial)...
94eg! is offline
Old 06-22-2008, 06:27 PM
  #9383
Only if you desire to use a body that has a low front profile where a standard shock tower doesn't fit. Tamiya has three or four bodies and PTI has two.
AreCee is offline
Old 06-22-2008, 07:45 PM
  #9384
Anynoe uses the Tamiya NSX body for their 05 or 05R? Is there significant difference between a "lightweight" and regular body?
stocker is offline
Old 06-22-2008, 11:06 PM
  #9385
Skitee's Avatar
Stocker there is a weight difference you can feel without using a scale, they are a little fragile when it comes to taking impacts especially if the body has plenty of detail in front.
Skitee is offline
Old 06-23-2008, 02:44 AM
  #9386
Thanks! Good information there.
How would one change the FDR for drifting on low grip (smooth or tiled surface) and high grip (asphalt)?
stocker is offline
Old 06-23-2008, 03:14 AM
  #9387
Skitee's Avatar
Depending on the type of drift tires you're using ofcourse...
You could possibly use the same FDR on both surfaces, however if your drift tires are generating some grip on the asphalt then you'll want to run a higher FDR(HIGHER NUMBER) by using a slightly smaller pinion which will allow the drivetrain to spool up faster and break traction more easily.
Skitee is offline
Old 06-23-2008, 05:10 AM
  #9388
DJ
Originally Posted by bviktor
Hi Dj,
We use 105t spur.
ciao
thanks for that number of pinion i can surely get 1 that can fit to my style
DJ is offline
Old 06-23-2008, 05:15 AM
  #9389
DJ
meaning, its only body thats count on shifting my TA05 to TA05IFS, and not much diff in performance.
thanks
DJ is offline
Old 06-23-2008, 05:25 AM
  #9390
I am absolutely sure that 1 pinion is not enough. If you want to save money you should buy min. 33-37T.
ciao
bviktor is offline
