Tamiya TA05 Touring Sedan
#4696
Originally Posted by Scarab
Can someone posts their successful TA-05 setup for running the indoor asphalt @ Fredrick's Coliseum? I'd like a baseline good setup to start with so that I can tweak it to my tastes.
Thanks,
Scarab
Thanks,
Scarab
-ult
#4697
Originally Posted by ultegrasti
the layout just changed, very different. go practice up there and start to form your own catalog of data to see what works. you dont have much experience with touring cars, so u have a steep learnin curve. this is prolly the kinda of thing you should have posted instead of ventin bout can motors. hope people still offer advice though.
-ult
-ult
#4698
You might add 2mm role center to the rear
just my2cents
just my2cents
#4700
-ult
-ult
Offering opinions shouldn't get me crucified...I hope...
Scarab
#4701
stiffer springs all around, heavier fluid than stock. play w/front bars. dont leave too much droop in the car. give the car a rollout around what the motor likes, make sure the car is as 'free' as possible. tamiya is notorious for droppin some slugs for bearings in the kits. cs32s and a '6 lid to start.
-ult
1 way if u can stand the brakin loss and attitude change...that or a spool if ur balsy and runnin can class.
-ult
-ult
-ult
#4702
Originally Posted by RCGaryK
What driveline? Dual diff? Diff/center one-way? Dual one-ways? Fixed center pulley/spool? Details chris, details!
EDIT: i always use a front one way. never really tried a front diff... but since i run mostly stock 27T... a front one way has more corner speed
WHAT DO YOU RUN gary?
#4704
Originally Posted by Hebiki
40wt oil (tamiya yellow) kit springs..and kit shock locations.
#4705
I run stock setup, stock oil, stock towers with TRF shocks, universals and the upgrade diff halves. White fronts and yellow rears, no bars at all. Down 1mm on front roll, up 1mm on rear roll, little bit of forward roll in the car at neutral.
Made the A the last three TCS races I was in, finished second in Memphis, so something must be in the ballpark. And oh yes, beat Gary.
#4706
Regional Moderator
Scarab
Scarab
Don't EVER let the fear of pissing off people keep you from offering up a valid opinion on the boards. Personally, I didn't see anything wrong with your original thoughts about silver can racing. People just don't like to hear alternate opinions...so forget them I say.
Don't worry, if you need help, theres always people around to answer, even if others are still pouting over someone thinking differently than them.
#4707
#4708
Location: Beautiful Downtown L.A. Where the sky is always on fire and the grass is always brown
#4709
#4710
Big Al-
Two hole pistons all the way around, diffs on both ends.
