Tamiya TA05 Touring Sedan
#3767
MikeR.. Do you happen to have the part # for the alum. dog bones. Couldn't find them on tamiyausa? I thought the hcca bearings were approx 2-3 grams lighter per bearing?? Which leads me to think that a 28 gram (approx.) weight savings could be achieved, not to mention the rotational weight savings. Thanks--Al
#3768
Originally Posted by CIVIC91
It doesn't need to be all blue to kick a$$!
(Surikarn susp blocks)
Finished 5th in the Seattle GT1 TCS. The other one, my son broke a rear outdrive on the first lap. I think all the rest were those fancy carbon fiber cars.
Fred
#3773
I don't see how you'll lose that much weight with ceramics since the biggest stock bearing weighs only 1.9 grams on my digital scale.The smaller axle bearings weigh half of that.
#3774
Originally Posted by maxepower
LARGE ASPHALT TRACK- RUBBER TIRES
Front
Arms : lw
Toe : 0
Camber : 1.5
Shock Mounts : outside hole on shock tower and middle of the three holes on the arm
Shocks : 400 tamiya with 2 hole 1 red sponge
Blocks : 1X Front and 1XD Rear
Arm Spacing: front block/1mm/arm/the rest/rear block
Ackerman : front hole on the steering knuckle
Upper Link : middle hole 4mm up
Downtravel : 24.6mm measured from top of axles to setup board =(droop)
Springs : yellow
Swaybar : none
Ride Height: 5mm with TakeOff CS27
Rear
Arms : lw
Toe : 3 degrees
Camber : 1.5
Shock Mounts : in one hole on shock tower and inside of the two holes on the arm.
shocks : 300 tamiya with 2 hole 1 red sponge
Blocks : 1XC front and 1B rear
Arm Spacing: front block/the rest/arm/2mm/rear block
rear upright : 0 degree aluminum middle hole no spacer
Upper Link : middle hole on rear upright, middle hole on inside mount no spacer.
Downtravel : 25 mm measured from top of axle to setup board=(droop)
Springs : yellow
Swaybar : none
Notes:
CF shock towers front/rear. 5mm clamp-on wheel hex. 46mm swingshafts. Hop-up diffs front/rear setup with front tighter than rear. Dual Rate on radio 85%. Expo -15%. 0.7mm spacer epoxied on steering knuckle to decrease steering throw.
Front
Arms : lw
Toe : 0
Camber : 1.5
Springs : yellow
Swaybar : none
Rear
Arms : lw
Toe : 3 degrees
Camber : 1.5
Springs : yellow
Swaybar : none
Notes:
Pretty interesting. About the fr. block (1X and 1XD) so it's 2 deg. Am I correct ?
What's the different between 1XD and 1D ?
You don't put any spacer below those blocks to make anti-squat, anti-dive ?
How about the caster angle on C-hub of lw suspension ? Is it 2 degree ?
Arms are lw. but you use 46mm, is it okay ? No rubs the alum ring ?
Thanks for the setting, I might try.
I'm after a setting for long straight with big sweeper then C curve - short straight - chicane - medium straight - S curve - back to long straight.
#3775
Originally Posted by Slotmachine
I`m trying it this weekend , I`ll let you know how it goes............
#3776
hey big al the only performance parts i have put in is a front 1 way and centre 1 way and thats pretty much it.
i have been looking at the carbon tub from tamiya to stiff it up abit more.
am also looking for a good setup and gearing for a tight track with a 25m straight(out side)
kind regards ash (tamiyamanuk)
#3777
any1 have an idea on how much gear i'd have to drop off goin from a silver can (GT3) to a sport tuned black can?
right now i'm runnin 43/104 (5.4x:1), i know i can go 44 w/o issue, but i have silver can now w/a lil more rpm. i know paulie (slot) used 46/106 (5.1x:1 or so).
but i wanna run the black can in wkly stock races, see where its at and to save $$ i cant afford on keepin monsters/cobalts purrin' nicely. thx
love this car, although 75g off the car would be nice.
-ult
-ult
#3778
-ult
-ult
Paul
#3779
well my 4holes dont seem to pull the touring car, lack of tq possibly. what u think paul, 41/104?
-ult
-ult
