Tamiya TA05 Touring Sedan
#3511
Originally Posted by mrodney
hey ray. No they use all of your Tamiya hardware without a problem. I ran them for the 1st time tuesday and had no problems. I got the 12.00 ones of the eBay guy, I don't see how the 36.00 ones can be that much better.
#3512
DIFF FIX:
Use the Yokomo Diff rings # ZS-506 from Speedtech. Will work for the 415's too.
They are hardened and have one run side, will last a long,long time.
Use Acer ceramic diff balls, 3mm. Carbide balls work well too, but have have the Acer's in for 2 years without probs.
Put some Tamiya AW grease in your palm and rub the diff balls in to get get the lube on them, install and add 1 tinny drop of oil on each ball.
For the thrust brg, which seems to be the major rough part, I have found using
Sta-Lube moly-graph engine assembly lube, found in good auto parts stores, last the longest.
I have used this in 4 hour enduros, with a siver can, and not have any problems.
Works for mod motors for a 2 day race without a rebuild.
Fred
Fred
#3513
BANE
Originally Posted by Bane
Anyone know of a shop that still has the TRF Special Blue shocks at a decent price (in the US being the key). I like the blue which is why I havnt gotten the newer "gunmetal" ones. Are they both just as good for my TA05???? Also trying to fing the titanium screw kits as well. THANKS!
#3515
Originally Posted by Slotmachine
I just put the Aramid belts on my ta05 and they feel stiffer then the stock ones after they are worn in....................
#3518
Regional Moderator
Originally Posted by C_O_jones
DIFF FIX:
Originally Posted by maxpower
One last note on diffs. Use ceramic balls and atlas diff covers and your diffs will last twice as long and you can reuse the ceramic balls even after it's time to replace the plates!
Just my 2$
Just my 2$
Thanks for the tip guys.
#3519
Does anyone know the actual sizes of the bearings for the TA05? I cant seem to find the sizes anywhere so I can upgrade the stockers. Figured I would sell the stock kit bearings and upgrade to Avid bearings but I need the actual sizes.
#3523
Hey guys...awesome thread!
1. Have any of you got an gear (final drive) chart you could send me?
2. Also what size spur gears have you been able to fit on the car without poking through the bottom of the chassis?
3. I bought the Raybrig (sp) chassis is it legal (TCS) to open the cooling air hole on the top of the body?
4. Are the new TA-05 parts TCS legal? I.E. the lightweight chassis etc...hope so just bought it.
[email protected]
Paul
[email protected]
Paul
#3524
Originally Posted by Darkseid
Sure you didn't just warp your front wheel?
#3525
Steve Wang
