Tamiya TA05 Touring Sedan
#3301
Regional Moderator
Originally Posted by bigb11
do you think tamiya will make a ta-05r kit?
And now, with the apparent problems with some peoples carbon chassis, there might be a debate about whether the "R" version should come with the carbon tub or graphite plate.
#3302
Originally Posted by Darkseid
Theres no doubt that they will, the only question is when.
#3303
What's this part for
Just browsing through all of this thread and found something interesting...
Found it on page 10
Just look at the picture....
What part is it ? Is it option ?
Any effect putting this part ....
I see that we can also attach this part from the center to the front bulkhead...
Any comment ?
Thx
Found it on page 10
Any comment ?
Thx
#3305
Originally Posted by Jack2
its just a turnbuckle I believe, It just reduces some chassis flex...
But the turnbuckle itself is too long.. Maybe they take it from the buggy ?
#3307
double post
#3308
Originally Posted by C_O_jones
Or, just make your own.
fred
fred
Fred may I see you electronic layout on the chassis. My receiver seems too big to fit on the chassis, unless I put it on top of the servo. Sanwa RX-311.
Thx for the pics.
#3309
The TA04 used to have that up front but i decided to take it out because my car seemed to have wandered at times (maybe there was a bind beacuse of those rods) . So what is the purpose of that C_O jones? seems interesting.
#3310
Does this mean some of the newly released carbon tub chassis's are not flat?
Brant
#3311
Originally Posted by akuhon
Ohh yeah... nice turnbuckles...
Thx for the pics.
Thx for the pics.
#3312
Dude, the RX 311 receiver will fit, I run them with my M11 transmitter and mine fits just behind the servo. I will admit its a pretty tight fit, there's not much room on either side but it does fit. You may have to pull the spur cover off to get it in as the antenna mount gets in the way abit.
Thx for the info, I plan to change with FUT 9550 servo since it's shorter than std. Hope I have more space for the rcvr.
Also, I see there are not many option for spur... before it comes out of the bottom spur hole on the lower deck... What the max. spur for either 48P or 64P ?
#3314
Thanks Jack2, you're right it's really tight side to side... I can manage it but just affraid if someone bump me on the side, my rcvr box will crack....
As to max spur sizes, 105t in 64dp is about as big as you want to go, and 78 in 48dp is about as big as you want to go.
The S9550 servo's are great, I run them in my MSX, but you don't need one in the TA05 for the RX to fit, mine has a standard size servo and everything fits great.
#3315
I ran a PRS 108t spur in my car and didnt have a problem.
