Tamiya TA05 Touring Sedan
#1861
Originally Posted by Key500
Does anyone have a setup for this car for like if I was to run at So-Cal or Tamiya in Ca....
Like what's a good tire and are RP rubber tires good..
So far I have yellow springs all around with I believe 35wt. oil with one piston hole..
Andre
Andre
Tamiya yellow springs, 35W shock oil, 2 hole shock valve's up front, 3 hole valve's in the rear.
I also run a rather high setting for ground clearance. 5mm F/ 7mm R.
I know it sounds high but when my car squat's in the turns it hooks great.
Hope it helps.
#1862
if anybody is interested in buying a ta05 give me a holla. im selling mine due to some personal matters. its built already and i can include the ferrari body if u want. prepainted red. its got a stabilizer set in it. im asking for 150 shipped.
#1863
Diffs
Did anyone have problems with the stock diff outdrives melting/breaking? I want to get the car to run in 19-turn but I'm not sure whether the diffs will hold up...are they as weak as the stock TB-02 outdrives?
#1864
Out drive issues!
#1866
hi, guys just got my new TA05.
Just a quick question what shocks are best to buy.
I found this on ebay and i think they will fit but unsure
can anyone help.
If not can someone give me the part number for a very good
set that wil fit.
I am sure this imformation is in the forums somewhere but i cant find it.
please help
http://cgi.ebay.com/TAMIYA-1-10-RC-T...QQcmdZViewItem
can anyone help.
set that wil fit.
please help
#1867
TA-05 Tamiya Spool
Quick question for those who have already the Tamiya Spool for the kits. Would the spool fit the TRF414M? The reason I asked, it still run my 414M kit for club racing & I like the way the spool handles on my TRF415. No after market RC company made one when the 414M was in it's prime years ago. I tried installing the Tamiya spool for the TB EVO4 & it was a direct fit between the bulkheads but the center hole of the diff pulley was too small to fit over the diff housing (the hole on the diff gear for the EVO4 is bigger in diameter). Any replies would be appreciated especially replies from those who still have their 414M's. Thanks in advance.
#1868
The ones you have right there are pretty well the set.. Fluorine coated dampers.. it just all depends on what colour you want.. red, dark blue, gunmetal, or the newer light blue ones with ridges ("Special Blue"). They all use the same fluorine coated body with different caps. They'll all fit and work well with any Tamiya model.
Here's a similar conversation about them in this thread's page, complete with numbers and pics if you look around.
can anyone help.
set that wil fit.
please help
can anyone help.
set that wil fit.
please help
#1869
FYI, the newest TRF Damper Special Blue has been discontinued.
#1870
Got rid of mine...like the 04/02 better
#1872
Hi Guys,
Just want to post a quick note that we have Tamiya parts back in stock along with the following new parts for the TA05:
Tamiya 5mm Aluminum Short Ball nut (Blue/10pcs) to work with the upper shock mount spacer kit
Carbon Damper Stay Setting Spacer Set (blue)
Tamiya Titanium Coated Suspension Shaft 49.7mm for TA05 This replace the inner hinge-pins on TA05 with smoother Ti-coated hinge-pins
Tamiya 48mm Light Weight Rear Swing Shaft (Blue) 1 pair This is for those that have the LW suspension kit installed
Tamiya 3x28mm Titanium Turnbuckle Shaft (2 pcs) This is for the camber links on the TA05. 2 pair will complete the car.
Also be sure to take advantage of our Free shipping Weekend special
Steve Wang
Steve Wang
#1873
Would I be far off if I thought that the 48mm shafts could fit on the regular suspension (I see there's still quite a bit of some play with those 46mm dogbones, especially if you take those O-rings from the axle cups) and then you'd be ready for the lightweight at any time after that? Or is there still binding?
Any luck with 28mm foams with regular suspension? The rears are fine with 6mm hexes and 2.5mm of spacers, but the fronts are the same setup (can't put any more on) and are barely clear of the kingpin ballcups on top... I could run them, but I'm sure on hard turns the wheen can flex and touch them.
Thanks,
James
Thanks,
James
#1874
i am using lightweight suspension arm..
FRONT:-front front using 1 A block
--------front rear using 1 XC block
REAR:-rear front using 1 XC block
------rear rear using 1 X block
so can i use the 48mm long universal? is 48mm too long?
