Tamiya TA05 Touring Sedan
#1831
Selling off the remaining of my Tamiya stuff.
Here is my latest project, TA05.
http://www.fictionlab.com/mdreel/Daw...roject2005.wmv
PM me or look at the listing in Sell Thread http://www.rctech.net/forum/showthre...28#post1906528
Thanks.
Thanks.
#1833
Originally Posted by DOTMAN
Wow...music and everything.
I just finished my 05 rebuild this weekend. Rialto this weekend? or maybe LaMirada next weekend? 05's in 19T? Whataya say?
#1834
Tech Legend
Trader Rating: 51 (100%+)
Originally Posted by MDawson
Rialto is on if I can find a car to run. Go Getem OC!
#1837
Thanks.
Thanks.
I would have made a bid for it if I already didn't have one...
You will not have a problem selling it.
#1838
confused about blox
Hi all, could anyone tell me what blocks come standard on the TA05? I want to try Satoshi's FRONT:1X Front and 1XD Rear and REAR:1XC front and 1B rear setup.(With 0 degree uprights) I'd like to limit the amount of blocks I need to purchase by swapping around the standard plastic blocks. Is this possible? if so, is it a good idea? Is this setup possible without having to buy the LW suspension?
#1839
New pics of the 05. and yes i agree, i cant paint! lol too impatient.
Now has gone back to the stock setup. Handling is getting better, still not consistent enough for me. I liked the centre one way. Last weekend i made the sway bar (no LHS have a sway bar kit for the 05 and we have a big meeting this weekend) and also added the hardened arms. Still toying with suspension, and also wheelbase. But its a definate improvement from my old TC3 and TA04
#1840
Setup
Does anyone have a setup for this car for like if I was to run at So-Cal or Tamiya in Ca....
Like what's a good tire and are RP rubber tires good..
So far I have yellow springs all around with I believe 35wt. oil with one piston hole..
Andre
Andre
#1841
set-up
Hi, my name is Juan Aveytia. Are you running box stock set-up or do you have hop-ups on it like oneways and stuff. Let me know everything you have for the car and I will give you a good set-up to start with.
Just pm me.
Just pm me.
#1842
Just pm me.
Just pm me.
#1843
If any of you are looking for the Tech Racing kit, send me a PM
#1844
RE: SET-up
Originally Posted by Key500
Also here's a pic of car
Well it looks like your running same type of set up as me. I'm running the 415 blocks. Are you running the stock blocks? Can't tell from the picture! My car is not very dialed. It's loose coming into the turn slightly and pushes a little coming out of the turn. It's driveable but not perfect and if I run 19 turn with it, the condition amplifies. I thinking of putting narrow "X" blocks and then running the LT wt. suspension. I think this will help a lot! It did with my 415!
#1845
Originally Posted by maxepower
Nice looking chassis. How do you like your spectrum system?
Yes I'm running the stock blocks even though I do have the extra blocks, I just wanna try to get a nice setup and go from there and see how the handles. Plus I only want to run stock motors with mines...
I'm going to go to the track next week so hopeful I'll have good luck...
