Tamiya TA05 Touring Sedan
#1726
Steve Wang, any clue on when the Xenon/SpeedtechRC TA05 chassis will be in? I need it for carpet!
#1727
Need help. I don't have the manual or a blow-up f the TA 05. I need all the part numbers where the center gears are. The area where the spur gear is. I need the numbers of the gear that is next to the spur and there is another part that comes after that. Looks like some type of bearing/bushing? Thanks in advance!
If you know where to look for the blow-up version, please post the link. I can't find it on TAMIYA USA's site.
#1729
yeah man.....can't wait for the xeonon chassis to come out! the anxiety is killing me... by the way guys, what pinion and spur would you recommend if i am running 8-10 turn motor on prepared asphalt......kinda confused by the 48 and 64pitch thingy...THANKS
#1730
Had my first chance to wind out the TA05 in a schoolyard today. Was running my VFS-1 and a Green Machine Pro motor... Turns out that it IS quiet, that is, until I came across the previously mentioned "microscopic element in spur gear" noise. Quickly diagnosed and solved thanks to reading previous posts here
Now I just gotta figure out how to dial out the understeer problem I seem to be having!!
#1731
Are you running kit tires? If not what tires, compound?
Is the surface clean?
Is it stock set-up?
More info the better...
#1732
Rear Toe-in
Originally Posted by CIVIC91
Trying to figure this block thing out.
So the stock car comes with 2 degree rear hubs, and 0 degree inboard toe, right?
So if I want 1.5 per side, I want the X block in the front of the rear arms, and the XC in the rear of the rear arms?
Adn if I want 1.0 per side , I want the X up front and the XB out rear right?
I measured the locations of the holes for M4 and M5 parts and they were about 43.5mm (IE M4 and M5 are the same). I do think the M3 looked narrower when I was assembling it, but I did not think about measuring the holes before I mounted M3, so I am not certain. However, if M3 were the same distance as M4, then I do not think that Tamiya would have called it M3 at all (or they would have changed all the numbers for these parts). So I think that if the rear toe overall is 2 degrees, then the uprights may be either 0 degrees or 1 degree, and the rest of the toe-in is from the blocks. If I get a chance to disassemble the setup I will confirm this later (unless someone else does first).
#1733
Do TRF 415 diffs and spool and oneway fit in the TA05? If not regularly, can they be modified to fit?
#1734
NO
#1735
Originally Posted by tiggersz
JoeyE
The part go
Crescent Ring
9808019
Bearing
9805672
Spur Gear Holder
3455870
Pulley
51213
Pulley
51213
Plastic Bushing
9115157
Spacer
9808018
Bearing
9805672
Crescent Ring
9808019
JC
The part go
Crescent Ring
9808019
Bearing
9805672
Spur Gear Holder
3455870
Pulley
51213
Pulley
51213
Plastic Bushing
9115157
Spacer
9808018
Bearing
9805672
Crescent Ring
9808019
JC
Practiced with Surikarn last night. Pretty fun!
#1736
hey guys.. here are some pics of my TA05, its been posted up all over DRC, so here you guys go:
and a close up of my front end.
#1737
#1740
Yep, was set up according to manual, with kit tires, TRF shocks & yellow springs all around. Surface was dirty asphalt, them kids don't keep their schoolyard too clean!
I'll be running it again today, on a different surface, and will have different springs with me to try out. Figured I'd go to blues in the rear as a start.
Originally Posted by MYXTYPLYX
It will depend on lots of factors:
Is it stock set-up?
Is it stock set-up?
