LRP Touring Car Masters 2005
#121
It will be early morning for the States when Round 4 is completed.
Masami made the biggest jump he must have made the wrong change to the car inbetween 1+2. Looks like about 13 sec laps.
#122
Originally posted by Adam Hartzell
The Yok BD and HB Cyclone are identical the their shaft drive counter parts. The geometry on BD is exactly the same as the SD. The belt drive set-up is better for big tracks and the shaft is better for tight tracks. Thats why Masami ran the SD at the recent JMRCA stock nats. So no new testing was really required except to figure out final drive ratio.
#123
Kyosho ???
What I am interested in is: Did the Kyosho guys (Lemieux, Cyrul) show up ? And if so,which car did they use ?
#124
Rick-- You are right, the pivot points were changed althoughnot a whole lot so the geometry is close enough to say its the same. I think the problem with the losi is that the main pivot points (ie. the arm mounts and the hubs) are to close together. This leads to a car that would react very quickly, however it could be reacting to fast. This would force a driver to look for new tuning ideas while setting up the car. The fact that they have had a year and still can 't figure it out is what scares me about the car.
#125
When we are at the subject of "unnormal" cars:
Have anyone of you had a close look at the Corally RDX? The suspension geometry isn't anywhere close to "normal". The arms are short, and the upper links are long. The ackerman isn't quite good either. Despite of this Simo and Sakke make the car go fast, very fast.
The person who impresses me the most at the moment is Juho Levanen. Being up there with Rheinard, Masami and Hara pushing 23 laps. He still runs the TC4 right? Wow, thats amazing. The TC4 hasn't been going really well until now, seems like Juho finally cracked the TC4 nut.
#126
He'd cracked it at the worlds. You would be expecting Barry Baker to be the top AE guy.
#128
Makes you wonder if its only come out as they were already tooled up for the mouldings and had no option but to sell it as it had all come so far? Have you seen the hassle the guys have had on the JRXS thread about 3700's not fitting? On the same post one of the reasons for the delays in the car coming out was apparently the fact they were redesigning it to fit 3700's and 3800's and it seems neither fits without a lot of cutting Some redesign.
#130
here be the top 10 in masters after the 3rd round (for those too lazy to click)
1 249 Rheinard, Marc
2 229 Hara, Atsushi
3 219 Levanen, Juho
4 250 Spashett, David
5 251 Hirosaka, Masami
6 255 Groskamp, Jilles
7 242 Surikarn, C.
8 239 Leino, Teemu
9 252 Andersson, Jonas
10 223 Völker, Ronald
2 229 Hara, Atsushi
3 219 Levanen, Juho
7 242 Surikarn, C.
8 239 Leino, Teemu
#131
Barry Baker, who is that??
I knew Juho was good, but not extreme. Being one of the 4 persons to have 23 rounds. The three others have won a couple of WC's summed up.
The Schumacher team is doing well also, with Andersson and Leino in the top ten.
@V12: Do you hav any pics of any prototype Schumacher drivetrain? Something like a more conventional belt-setup?
#132
R/C Tech Founder
Originally posted by Erlend
Stop using bad excuses to cover up the poor carpet/rubber performance of the JRX-S. They have had the time it normaly would take to make a new car work in different conditions. The team drivers have had the proto for almost a year now.
Doesn't Hupo Hönigl run the JRX-S? He is a touring guy and is used to rubber on carpet. When he can't make the car work then something must be wrong.
Much of Losi's team, at least their US team, are very good drivers but are not on the on-road level of guys like Rheinard, Surikarn, etc. No one can argue that.
#133
@V12: Do you hav any pics of any prototype Schumacher drivetrain? Something like a more conventional belt-setup? [/B]
For your information, only Teemu and the new Sweeden champion run for Schumacher.........
Jonas = TAMIYA 415MS = Team TRF
#134
Oh no, my bad. That makes the Tamiya train even stronger.......
It seems to me that Matt Francis is quite capable of doing well in touring. As mentioned in my post, he was in the A-main last WC. Everyone else sucked, since Francis placed so high? Or?
#135
Spec Top 10
1 249 Rheinard, Marc - TRF415MS / ORION V2 RE / HARA TWISTER
2 229 Hara, Atsushi - HB CYCLONE / ORION V2 RE or HE / HARA TWISTER
3 219 Levanen, Juho - TC4 AE / REEDY / Q2 LRP
4 250 Spashett, David - TRF415MS / PEAKPERF V2 SE / Q2 LRP
5 251 Hirosaka, Masami - YOKOMO BD / REEDY-YOKOMO OZ / RAYSPEED KO
6 255 Groskamp, Jilles - XRAY FK05 / PEAKPERF V2 / Q2 LRP
7 242 Surikarn, C. - HB CYCLONE / ORION V2 RE or SUE / ?
8 239 Leino, Teemu - SCHUMACHER MI2 / ORION V2 / ?
9 252 Andersson, Jonas - TRF415MS / PEAKPERF V2 SE / Q2 LRP
10 223 Völker, Ronald - TRF415MS / ORION / ?
