Old 11-17-2012, 03:15 AM   #1
choomas's Avatar
Default rc drift set up and motor
hey guys lately i haven't been doing so well at a rc drifting racing. this racing is time attack and the track changes every 3-4 months and there's sometime 5 to 10 people racing so it dose get pretty hectic.
so i was thinking i should get a new motor but each web page say something else. this is what im running
Make: Yokomo
Model: DRB ssg with Team Bomber chassis
Track is what they used for roads
Tire: Yokomo Super Drift Tire Zero One R2
Motor - ESC: hobbywing 21.5t sen - hobbywing 120 amp
Caster and Camber: 3 with overdose aluminum C Hub & Upright Set-up 6-8
Steering: overdose Aluminium Steering Crank Set
Toe: 0
Kick up: no idea
Ride height: 7 MM
Springs: stock pick
Bumper weight: 0
Shock Oil: 450
Other: Fluorine Resin Shock Piston Set piston.
sway bars: harder
Camber: 2
Toe: stock
Kick up: 0 MM
Ride height: 8MM
Springs: stock black
Shock Oil: 350wt
sway bar: soft
Front: 40 spec r geared diff with 1000 oil
Rear: 40 lock stock
drive: stock 15
Spur: 68
Pinion: 45
ratio: 3.9
shocks postion: in picture
ask if you like me to post esc settings
so is my settings alright if not what some suggestions and what motor and brand i should get if have to?
choomas is offline   Reply With Quote
RC's Stuffs Buy and Sell Hobby Peoples Indonesia Racing 5809 11-09-2015 06:15 PM
What is the best rc drift car currently? Kaifd3s Electric On-Road 38 07-15-2013 07:11 PM
Bintulu Sarawak RC Drift vipb0yz Malaysian R/C Racers 191 09-29-2011 05:46 AM
SEO by vBSEO 3.5.0
