Old 06-12-2013, 04:09 PM   #106
scooby61's Avatar
Originally Posted by Jstall7543 View Post
Yes! Were you able to find a decent price on the cvd's? The 2650kv has got serious balls compared to the the 2500kv stock motor. I'm running the hpi tork 2650kv and castle esc, it's scary fast on 6s. I did buy the high speed diffs though.
Like 34 for the pair the rtr already has them in front but I don't like dogbones in the rear. Will prob do the center ones in a month or so. I won't be running 6s we have a 4s limit on 8th scale at my track .
scooby61 is offline   Reply With Quote
Old 06-13-2013, 02:39 AM   #107
Jstall7543's Avatar
Where did you find the rear cvds for that price? I need some too!
RC is a way of life and a ridiculous hobby.
Ridiculously Fun! Subscribe to my YouTube Channel! Or ELSE! Hehee! http://www.youtube.com/user/Jstall7543
Jstall7543 is offline   Reply With Quote
Old 06-13-2013, 08:20 AM   #108
scooby61's Avatar
Sorry typo there 54.00 from nitrohouse wish they were that cheap
Old 06-13-2013, 01:22 PM   #109
Jstall7543's Avatar
Oh ok, for a minute there I thought someone was actually seeling the cvd's at a decent price...
Old 06-14-2013, 06:17 AM   #110
scooby61's Avatar
cva s installed , castle 2650 installed, mamba monster 2 esc installed.
Just found one problem though my grp rims are just barely rubbing the screw on on the end of the steering linkage. Any suggestions this is the spec tire for 8th scale at my track so I have to run them.
Old 06-14-2013, 07:45 AM   #111
Jstall7543's Avatar
I posted on day one that the sweep wheels rub at 90% full lock also. I'm not sure why a team c/ofna race car wouldn't allow for a standard wheel without rubbing considering neither company makes real race tires. I was thinking maybe wider front hubs or different end links would be the only options other than limiting your end point adjustment on a good radio, that's what I did...for now. The stock wheel has a larger I.D. so I assume good tires wouldnt stretch over the stock wheels either. Thank you ofna/team c! That's really smart. The good news is the car has more steering than most.
Old 06-14-2013, 07:48 AM   #112
Jstall7543's Avatar
You could champher the inside edge of the front wheels with a dremal drum sander to maybe provide a little less rubbing. Maybe dremal the end link a little too.
Old 06-14-2013, 09:14 AM   #113
scooby61's Avatar
Mine are not rubbing at full lock but rather the inner inside edge is rubbing on the back of the screw head that holds the linkage ball on the steering knuckle
Was thinking of grinding 1-2 mm off the top of the ball link should let me drive it down enough to clear without altering steering geometry. Wish I could get some of this slop out of the left front as well though the left tire flops around way more than the right
Old 06-14-2013, 10:05 AM   #114
Is Team C is available in the market or the stopped building GT
Maverick143 is offline   Reply With Quote
Old 06-14-2013, 10:07 AM   #115
Jstall7543's Avatar
I just looked at mine again and the wheel is actually rubbing the back of the arms outside the hinge pin area and due to the spoke design of the sweep wheels its pretty bad. Lucky fo me im just going mostly straight. I might clearance the wheels and edge of the arm a little.
Old 06-14-2013, 10:11 AM   #116
Jstall7543's Avatar
Im not sure, seem like ofna has the rights to the car in the usa. You can buy some team c parts from rcboyz in the usa.
Old 06-14-2013, 10:17 AM   #117
Jstall7543's Avatar
It looks like after I clearance the wheel and arm it will rub the outer tie rod next....
Old 06-14-2013, 10:20 AM   #118
scooby61's Avatar
Old 06-14-2013, 10:26 AM   #119
Jstall7543's Avatar
Gt-v2e sweep wheel rubbing rubbing right here! Thats the back side of the front arm outer hinge pin.
Old 06-14-2013, 10:31 AM   #120
Jstall7543's Avatar
Look what I got in a ebay auction. $40.60 the size is much smaller than I expected. Between this and my bushnell velocity radar gun I should be able to accurately gage the speed. Im almost ready for another speed run.
What 4X4 SCT is this? coaltrain Electric Off-Road 9 10-25-2012 08:23 PM
