OFNA GT-V2e 1/8 GT
#751
Check out my youtube channel Jstall7543.
#752
Marcus, I have been on the site and cannot find the FF pivot block...
are you still making them?
Ps i just opened up my parcel after all this time and realised i never ordered the arm braces
I am back!! seems like there are some users that still want to talk about the OFNA GTV2 chassis so I did some research on front geometry and came up with this FF pivot block that gives you anti-dive and dynamic caster at the same time. what this relates to is that the car gets more forward traction and under decel eliminates weight transfer so the rear doesnt get unstable under braking! under acceleration the car "stiffens" up much like anti squat does in the rear!
What are you OFNA guys doing for rear toe and antisquat? I drew up a 1* toe block but i have concerns about the rear slop which is inevitable with RC cars. By nature the rear tires tend to "toe out" under acceleration so if i make a toe block for 0 or even 1* the car will probably be really unstable.
CK i tried to get it done before your order went out but i figured you wanted your stuff ASAP!!
I am also working on a contingency program for you speed freaks!!
the RCShox arm braces work wonders at high speeds on the track so will be great for high speed runs and they are aerodynamically better for the underbody since they are flat.
RCSHox 2 stage pistons offer superb stability for rough roads.
RCShox steel shielded bearings are just faster than any rubber sealed bearings
RCShox FFpivot "speed" block coming soon
and RCShox FR toe "speed"block coming soon once we figure out what optimal toe and Antisquat is!
Gimme a couple of days and what i will probably do is give you guys a code to enter in when you order and i will throw some test parts in with your order to give me feedback on, once again thanx for your support and all of your PM's. I could possibly have a line on some dedicated high speed bodies but not sure if i can close the deal or not at the very least i may be able to swing a few samples!
#753
I have a spare 40T 8mm bore spur Gear if someone is looking for one. Bought it from kershaw designs but I need to go smaller. Send me a pm if interested
#754
Can anyone tell me what kind of body options do we have for this size car and the best place to get them. Mine came with the vette body, but with the cold Michigan air it cracked.I'd like to get the f type Ferrari body and paint it myself. Just need to know who has the best deal on bodies. Tacon 2000Kv motor, stock toro esc, 20t pinion. Also I tried to loctite the set screws in the drivetrain, but mine are so tight I didn't want to strip them. Love the car but it's so cold and wet she's just a shelf queen for now. I'd love to post pics but not possible on this phone.
#755
Watch "OFNA GT-V2e Road To 100mph New C6R Body" on YouTube
https://www.youtube.com/watch?v=wbK9...e_gdata_player
There is also the trusty world renowned warrior body that's probably your best bang for your buck and one of the fastest body's around, up to 10mph faster over 100mph! Shown here on my YouTube channel. SUBSCRIBE PLEASE!!
Watch "GT-V2e ECKO EXPRESS ipanema Warrior" on YouTube
https://www.youtube.com/watch?v=qZ0H...e_gdata_player
Then there's the bodies on Rcshox (GT8L only) but I can't get the website to work correctly on my Galaxy note3 so I assume there's something going on with the site.
Hope this helps! It's the off season right now but I'll be hitting hard again this summer. Check out my Road to 100mph series I did over the summer. It follows most of last summers build. I'm going big next time out! 8s
#756
Thx j. Just subscribed. Do you think 20t pinion is to much for parking lot runs. Nothing serious. I'd be happy with 50 many 60 mph out of this car. It's got the new tacon 2000Kv motor with that toro 150a esc but if the esc blows I got a xerun 150a ready to go in it. Just looking for a setup to run cool on straights and turns just like a track on 4 or 6 cell. Wish I could test if for temps but it's retarded outside right now.
#757
Ya, it's hard to say but the temps will tell the story. Personally I found the toro esc to get hot quick and pails in comparison to a mamba monster. I'm running the original gtv2e electronics in a gtp2e drift car on 5s and it gets hot in about 5min and starts cutting out and I shut it down. Next summer I'll be running Mamba XL2 on 8s.
I meant subscribe to my YouTube channel too!
#758
I did find a non-kyosho Audi R8 and MB SLS AMG body while I was in Asia.
#759
#760
SUBSCRIBE PLEASE!!
Thank you very much for your kind words.
It’s great to see people enjoy outstanding top-speed results from using the aerodynamically proven Ipanema Warrior GT race body.
Good luck during your new year of high speed running!
#761
Hi guys,
I just sold my GTP2-e and I'll order a GTPV2e Pro.
I will use the same motor and ESC that I used on my GTP2, a RX8 with T8 2650kv. I just run on track, no bashing, and I was using a 20T pinion. What pinion size should I buy or I keep the same 20T?
Another question, I'd like a recomendation of a good servo bellow $100.
Thanks in advance,
Roberto Pompeu
Thanks in advance,
Roberto Pompeu
#762
www.eurorc.com
www.rcshox.com
Neither sell the benz body but I think Marcus @ rcshox mentioned he could possibly get it.
www.rcshox.com
#763
Any of you guys know where to get aftermarket springs for the front?
I'm looking for springs around 1.5" length with different spring rates.
#764
Just ordered a new Ofna GT-V2e from Tower.
Anything else I should do before running it besides checking all screws and wheel nuts?
This car will be mainly ran in races, not for straight speed also.
Cheers
Cheers
#765
If u order the RtR version then you might want to swap out the esc,motor,servo,get yourself some cvd driveshafts if you plan todo any real racing . If just parking lot racing then just run it out the box
